Query Widget Related Tables Popup configuration
3024
6
02-08-2018 07:19 AM
MaureenKerr
I am using the Query Widget in my app and the data layer that I am querying has Related Tables attached.  On set up of the Query Widget it offers the ability to configure the Query Results using the configuration set ouf for the pop ups in the web map.  This comes through perfectly for the main layer popups, but when I select the related table information it seems to ignore the webmap configuration and pull all the titles etc straight from the MXD, this leaves me with fields such as Object ID apearing in the table which I don't want as well as ignoring the popup title configuration that I had set out to help differenciate between the realted tables.  Is there a way to fix this or for me to manually configure the related tables popups in the query widget results panel?
Maureen
RobertScheitlin__GISP
Maureen,
   This is a known issue and there is an enhancement request in the system to fix this.
Maureen,
MaureenKerr
Hi Robert,
Thanks for your quick response .Ok that is good to know, is there a list somewhere I can check the status of the request or do I jsut wait and see what happens?
Maureen,
   Seems like they are saying it is implemented already:
https://community.esri.com/ideas/11131
MaureenKerr
Hi Robert,
Not quite what I was looking for, I was able to format the Related Tables pop ups in Web App builder no problem.  The issue I have is that the formatting I have done does not follow thorugh into the Query Widget.  Perhaps I should add it to the Ideas list
Yes That would be a good start. You may also want to contact esri tech support and submit an enhancement request for this too.
MaureenKerr
OK I'll see how i get on with that, thanks for your help Robert
