Generate/populate lat and long fields in ArcMap and Collector
3395
02-06-2018 01:27 PM
AlexP_
ArcMap 10.5.1 and Collector 17.0.3 How do I set up generate / populate lat and long fields in ArcMap? I am trying to collects lat and long when it is located in Collector. Please advise. Thank you
RandyBurton
You can set your feature to Record GPS metadata.  The fields ESRIGNSS_LATITUDE and
ESRIGNSS_LONGITUDE will contain lat/lon if you are collecting using GPS location.  If you click on the screen and select "Collect here" the fields will be left blank.
Tagging https://community.esri.com/community/gis/applications/collector-for-arcgis
shan_sarkar
Alex,
  1. What kind of database are you using for this service? If you working on SDE you can have triggers in place which can calculate the XY in two different fields.
  2. You can also create a Python script with the Add XY Coordinates—Help | ArcGIS Desktop and execute the script using a Windows Task Scheduler. This method should work for all feature classes irrespective of the database.
I hope this helps!
~Shan
~Shan
RandyBurton
