Cannot Get value: data-dojo-attach-point
10985
17
01-24-2018 08:11 AM
JamesCrandall
Attempting to build a new widget and having difficulty acquiring the value found in a textbox control in the widget.html and getting the error: "this.<name>.get is not a function".  Hopefully I'm just missing the obvious.  And thanks to Robert and this group for the jumpstart!
Widget.html (line 5 has the appNoInput reference I'm trying to get the value from)
<div>
  <div data-dojo-attach-point="tabIdentify">
    <div class="my-tab-node" data-dojo-attach-point="tabNode1">
      <div class="main-div" data-dojo-attach-point='mainDiv'>
    <label for="${id}_appNoInput">App No: </label><input type="text" class="appNoBox" id="${id}_appNoInput" data-dojo-type="dijit/form/ValidationTextBox" data-dojo-attach-point="appNoInput" data-dojo-attach-event="keypress:_onSearchKeyPress" />
    <br/><br/>
    <div class="jimu-btn" data-dojo-attach-point="queryButton" data-dojo-attach-event="click:_onQueryAppNo">Query App No.</div>
     <br/><br/>
....and so forth
Widget.js
var appNo = this.appNoInput.get("value");
//generates the error "this.appNoInput.get is not a function"
Tags (1)
RobertScheitlin__GISP
James,
  So here is your Widget.js working now. Sometimes very simple things that are not obvious can get you and your case was the BaseWidget has to be listed before _WidgetsInTemplateMixin in the declare array:
define(['dojo/_base/declare',
    'dijit/_WidgetsInTemplateMixin',
    'jimu/BaseWidget',
    'jimu/dijit/TabContainer',
    'jimu/utils',
    'dojo/_base/lang',
    'dojo/on',
    'dojo/Deferred',
    'dojo/_base/Color',
    'dojo/_base/array',
    'dojo/dom-construct',
    'dojo/dom-class',
    'dojo/keys',
    'dijit/form/ValidationTextBox',
    'esri/tasks/query',
    'esri/tasks/QueryTask'
  function(declare,
    _WidgetsInTemplateMixin,
    BaseWidget,
    TabContainer,
    utils,
    lang,
    on,
    Deferred,
    Color,
    array,
    domConstruct,
    domClass,
    keys,
    ValidationTextBox,
    Query,
    QueryTask
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: "jimu-widget-customwidget",
      startup: function() {
        window.map = this.map;
        window.widget = this;
        this.inherited(arguments);
        this.lookupLayerUrl = this.config.lookupLayerUrl;
        this.queryTask = new QueryTask(this.lookupLayerUrl + "/1");
      postCreate: function() {
        this._initTabContainer();
      _initTabContainer: function() {
        var tabs = [];
        tabs.push({
          title: 'Tab 1',
          content: this.tabNode1
        tabs.push({
          title: 'Tab2',
          content: this.tabNode2
        this.selTab = 'Tab 1';
        this.tabContainer = new TabContainer({
          tabs: tabs,
          selected: this.selTab
        }, this.tabIdentify);
        this.tabContainer.startup();
        this.own(on(this.tabContainer, 'tabChanged', lang.hitch(this, function(title) {
          if(title !== 'Tab 1') {
            //do something now that Tab 2 has been selected
        utils.setVerticalCenter(this.tabContainer.domNode);
      onReceiveData: function(name, widgetId, data /*,historyData*/ ) {
        if(name !== "eSearch") {
          // We only care about messages from the
          //    search widget.
          console.log('no esearch widget');
          return;
        console.log('onReceiveData fx')
        console.log('data.item.title: ', data.item.title)
        this.appNoInput.set("value", data.item.title);
      _onSearchKeyPress: function(evt) {
        //  summary:
        //      If the enter key is pressed, query for the app id.
        if(evt.charOrCode === keys.ENTER) {
          lang.hitch(this, this._onQueryAppNo());
      _onQueryAppNo: function() {
        console.log('_onQueryAppNo value: ', appNo);
        var query = new Query();
        query.where = "APP_NO = '" + appNo + "'";
        query.outFields = ["*"];
        this.queryTask.execute(query).then(lang.hitch(this, this._populateForm));
      resetForm: function() {
        this.mainForm.style.display = "none";
James,
   Do you have "dijit/form/ValidationTextBox" in your Widget.js define array?
JamesCrandall
Yes!
(this also made me go look/check and is helping me understand the various things I need to consider -- thanks!!!)
        'jimu/BaseWidget',
        'jimu/utils',
        'dojo/_base/lang',
        'dojo/on',
        'dojo/Deferred',
  'dojo/_base/Color',
  'dojo/_base/array',
  'dojo/dom-class',
  'dojo/keys',
  'jimu/dijit/LoadingIndicator',
  'jimu/dijit/Popup',
function(declare,
    BaseWidget,
    TabContainer,
    utils,
    lang,
    on,
    Deferred,
    Color,
 array,
 domConstruct,
 domClass,
 keys,
    LoadingIndicator,
 Popup,
 ValidationTextBox,
James,
   Can I see the whole function that this code is in:
JamesCrandall
           //  summary:
           //      When an application is queried via the widget,
           //      this function begins look up tasks.
           this.resetForm();
         var appNo = this.appNoInput.get("value");  //error occurs here
           console.log("appNo: ", appNo)
James,
  The scope of the function that your in there is different from the outer scope of it's parent function. So you use lang.hitch to maintain the scope:
      _onSearchKeyPress: function(evt){
           //  summary:
           if (evt.charOrCode === keys.ENTER){
           //  summary:
           this.resetForm();
James,
   Sorry look at my updated code above. I was try to do to many things at the same time when I posted that.
JamesCrandall
Thank you!  I'll take a stab at this shortly.
JamesCrandall
Just reducing it down to the couple of functions I'm having issues with...
        //  summary:
        //  summary:
        this.resetForm();
        //var appNo = this._getAppNo();
        var appNo = lang.hitch(this, this._getAppNo());
_getAppNo: function() {
        //  summary:
        //      Parse the current form application number.
        //this.appNoDiv.innerHTML = this.currentFeature.APP_NO
        return this.appNoInput.get("value").trim();
When looking at console.log('_onQueryAppNo value: ', appNo); it basically prints out the entire html for that control -- this is what shows in the dev tools log:
For the line in the widget.js
This is the log prints in Chrome dev tools console:
<input type="text" class="appN<input type="text" class="appNoBox" id="widgets_blah_Widget_36_appNoInput" data-dojo-type="dijit/form/ValidationTextBox" data-dojo-attach-point="appNoInput" data-dojo-attach-event="keypress:_onSearchKeyPress">oBox" id="widgets_RegExhibits_Widget_36_appNoInput" data-dojo-type="dijit/form/ValidationTextBox" data-dojo-attach-point="appNoInput" data-dojo-attach-event="keypress:_onSearchKeyPress">‍‍‍‍
James,
  I see not need for the _getAppNo function.
  //  summary:
  this.resetForm();
