Need simple example: add tabs to widget
18869
57
01-19-2018 08:44 AM
JamesCrandall
LaunchPad theme
WABDev 2.5
Custom Widget
I'm looking for the simplest, most straight forward example of adding 2 tabs to a new widget (an absolute vanilla panel).  THIS thread seemed to be close but I'm not seeing the expected result (no CSS example?).
Looking for the most basic form of HTML, JS and CSS to get this implemented.
TIA
RobertScheitlin__GISP
James,
 Try this. All I did was change the order of the modules in the define. It is recommended that basewidget and mixins be at the beginning of your array.
define(["dojo/_base/declare",
     "dijit/_WidgetsInTemplateMixin",
     "jimu/BaseWidget",
     "dojo/_base/lang",
     "dojo/_base/Color",
     "dojo/_base/array",
     "dojo/dom-construct",
     "dojo/dom-class",
     "dojo/keys",
     "dojo/on",
     "dojo/Deferred",
     "dijit/layout/TabContainer"
  function(
     declare,
     _WidgetsInTemplateMixin,
     BaseWidget,
     lang,
     Color,
     array,
     domConstruct,
     domClass,
     keys,
     on,
     Deferred,
     TabContainer
  return declare([BaseWidget, _WidgetsInTemplateMixin], {
               // Custom widget code goes here
               baseClass: "jimu-widget-customwidget",
               LoadingIndicator: null,
               currentFeatures: null,
               printOutlineLayer: null,
               printOutlineConnects: [],
               _isPreparedExhibit: false,
               startup: function() {
                    //  summary:
                    //      Called on initial widget load
                    //      This function sets all of our configurable variables to those set in the settings
                    //      page/file.
                    this.tab = new TabContainer({
                         tabs: [{
                           title: this.nls.input,
                           content: this.inputPaneNode
                           title: this.nls.output,
                           content: this.outputPaneNode
                         selected: this.nls.input
                    this.tab.placeAt(this.domNode);
                    this.tab.startup();
                    window.map = this.map;
                    window.widget = this;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
MVP Esteemed Contributor
This is how I've added tabs to my widget's Settings
Setting.html
<div class="esriCTTabDiv" data-dojo-attach-point="tabDiv">
  <div data-dojo-attach-point="agolSettingsNode" class="esriCTTabNode">
  </div>
  <div data-dojo-attach-point="prioritizationSettingsNode" class="esriCTFullHeight esriCTTabNode">
  </div>
  <div data-dojo-attach-point="otherSettingsNode" class="esriCTFullHeight esriCTTabNode">
  </div>
</div>
Setting.js
define([.., 'jimu/dijit/TabContainer3', ..], function (.., TabContainer3, ..) {
   _initTabs: function _initTabs() {
      var agolSettingTab, prioritizationTab, otherSettingsTab, tabs;
      agolSettingTab = {
        title: this.nls.agolSettings.agolSettingsTabLabel,
        content: this.agolSettingsNode
      prioritizationTab = {
        title: this.nls.prioritization.prioritizationSettingsTabLabel,
        content: this.prioritizationSettingsNode
      otherSettingsTab = {
        title: this.nls.otherSettings.otherSettingsTabLabel,
        content: this.otherSettingsNode
      tabs = [agolSettingTab, prioritizationTab, otherSettingsTab];
      this._tab = new TabContainer3({
        tabs: tabs
      }, this.tabDiv);
      this._tab.startup();
Which results in this:
JamesCrandall
Thank you, Ken.  Very much appreciated.  However, I am looking for a way to add tabs to an actual widget that is launched/opened --- for example the Geoprocessing Widget has two tabs.
Again, thank you!
KenBuja
This should work equally well in the main widget.
You can always see how that widget was built by opening up its code in the client\stemapp\widgets folder. In it, you'll see
        tabs: [{
      this.tab.startup();
JamesCrandall
That looks like it's right from the Geoprocessing Widget.js
I added that in my startup: function() but no tabs appear on the widget panel when it opens (no errors and widget does open).  I want the "AppNo" label & text box and "Query" button placed on a tab that appears at the top.
James,
  That looks like you do not have widgetsintemplate (I am on my phone so I don’t have access to the exact name and case right now) class added to you define list and in the array.
JamesCrandall
No worry Robert.  I'll check into the widgetsintemplate -- thanks!
I have "dijit/_WidgetsInTemplateMixin" in the define
That is it but you need it in the array after the define where baseWidget is listed as well (hard to explain from memory).
JamesCrandall
Not a problem, Robert.  This is essentially what I have after the declare() and function() --- both have the _WidgetsInTemplateMixin references.
//To create a widget, you need to derive from BaseWidget.
                    //  summary:
                    //      page/file.
                         tabs: [{
                    this.tab.startup();
                    this.inherited(arguments);
                    this.geoLayerUrl = this.config.geoLayerUrl;
                    this.lookupLayerUrl = this.config.lookupLayerUrl;
                    this.majorRoadsUrl = this.config.majorRoadsUrl;
                    this.streetsUrl = this.config.streetsUrl;
                    this.countyUrl = this.config.countyUrl;
                    this.countyFilterGPUrl = this.config.countyFilterGPUrl;
                    this.printTaskUrl = this.config.printTaskUrl;
                    this.geometryServiceUrl = this.config.geometryServiceUrl;
                    this.permitUrl = this.config.permitUrl;
                    this.canalLayerUrl = this.config.canalLayerUrl;
                    this.queryTask = new QueryTask(this.lookupLayerUrl + "/1");
                    this.adminQueryTask = new QueryTask(this.lookupLayerUrl + "/3");
                    this.populatePermitFieldData();
                    this.createFacilityFeatureLayer();
James,
  so you have it in your define and your declare right? You did not post your define portion.
