Open Table in HTML from Button
2380
12-18-2017 01:24 PM
BrandonPrice
I created a table that I have in my html that I am trying to access from a button (PMSelect) that I also have in my html. The table (script id="utilitySelectorTmpl") and javascript (utilitySelectorModule.js to query the restpage) to populate the table are done. I have not been able to open the table using onclick. This is what I have:
var utilitySelectorToolBtn = dom.byId("PMSelect");
   on(utilitySelectorToolBtn, "click", function (event) {
   if (app.isutilitySelectorModuleOpen === true) {
      app.utilitySelectorModule.hide();
      app.isUtilitySelectorOpen = false;
   } else { // not open
      app.utilitySelectorModule.show();
      app.isutilitySelectorModuleOpen = true;
I haven't yet specified the location of table when open. Maybe this could be the reason but I am not sure. This is a portion of my script:
app.utilitySelectorModule = {
   countyField: 'Cnty',
   routeField: 'Route',
   postmileField: 'DYNSEGPM',
   isVisible: false,
   template: {},
   panel: {},
   countyDllEl: {},
   routeDllEl: {},
   beginPostMarkerDdlEl: {},
   endPostMarkerDdlEl: {},
init: function () {
}, // init
show: function () {
   require(["dojo/on",
      "dojo/_base/declare", "dojo/dom-construct",
      "esri/tasks/QueryTask", "esri/tasks/query"
   ], function (on, declare, domConstruct, QueryTask, Query) {
         let ctx = app.utilitySelectorModule;
         ctx.isVisible = true;
         if (!ctx.panel.click) {
         ctx.panel = domConstruct.toDom("<div class='utilitySelectorPnl'></div>");
         domConstruct.place(ctx.panel, 'mainHtmlBody')
         template = $("#utilitySelectorTmpl");
         ctx.panel.innerHTML = template.html()
Attached are the two js files. Custom scripts has the button and utilityselectormodule has the query commands for the table. Any help is greatly appreciated.
Brandon
ArcGIS API for JavaScript
Web GIS
Web AppBuilder Custom Widgets
RobertScheitlin__GISP
Brandon,
   I have not seen this type of coding workflow before so it is hard to say whats going wrong. Are you even getting anything added to the mainHtmlBody?
BrandonPrice
Only the button appears in the map which was added to the map div in the html. The table does not show when you click the button yet. I believe it might be something not too challenging that needs some revision for it to work.
Brandon,
  Unfortunately I am having trouble following your code logic.
BrandonPrice
No problem. Thanks for the response. I will post any solutions.
