AttributeError: 'ServiceManager' object has no attribute '_services_list'
12203
14
11-21-2017 02:49 AM
KjellTimalm
Getting this error when running: "hosted_services = server1.services.list(folder='System')".
My GIS Enterprise version is 10.5.1 and the ArcGIS API for Python version is 1.2.4. Python version is  3.6.3
Running "server1.services.list" gives following result:
<bound method ServiceManager.list of ServiceManager at https://agsserver01.test.com:6443/arcgis/admin/services
Anyone having same error or seen this message?
JasonLee9
Kjell,
I also have this issue. I can see the folders when I make a call for a list. Maybe someone from ESRI can chime in on this.
Error message
KeyError                                  Traceback (most recent call last)
C:\ProgramData\Anaconda3\lib\site-packages\arcgis\gis\server\_common\_base.py in __getattr__(self, name)
82         try:
---> 83 return self._properties.__getitem__(name)
84         except:
C:\ProgramData\Anaconda3\lib\site-packages\arcgis\_impl\common\_mixins.py in __getitem__(self, key)
339         """
--> 340 return self._mapping[key]
341
KeyError: '_services_list'
During handling of the above exception, another exception occurred:
AttributeError                            Traceback (most recent call last)
<ipython-input-6-2884d629327a> in <module>()
----> 1 server0.services.list()
C:\ProgramData\Anaconda3\lib\site-packages\arcgis\gis\server\admin\_services.py in list(self, folder, refresh)
122             self._currentFolder = folder
123             self._folder = folder
--> 124 return self._services_list
125
126         return self._services_list
86                 if k.lower() == name.lower():
87                     return v
---> 88 raise AttributeError("'%s' object has no attribute '%s'" % (type(self).__name__, name))
89     #----------------------------------------------------------------------
90     def __getitem__(self, key):
PeterKnoop
MVP Regular Contributor
Esri Support reports this is a known issue with version 1.2.4:
BUG-000109673: Using the 'services.list()' function from the Python API fails with a traceback error.
The bug does not affect previous versions of the API, so one suggested workaround is to use version 1.2.3 instead.
PeterKnoop
This has been fixed in the 1.3.0 release, and services.list() now works as expected again.
JasonLee9
Looks like it may be broke again in 1.6.2. Anyone else seeing this?
EmilianoPetrelli
Hai all,
I have a similar problem with version 1.8.0 when I try to get list of ags's services:
ags = Server(urlAdminAgsMaster, None, username=adminUser, password=adminPasswd)
print(type(ags))
ags.services.list()
Output:
<class 'arcgis.gis.server.admin.administration.Server'>
'Server' object has no attribute 'services'
The same code works with version 1.6.0
I'm using Python API on a Conda Environment (no ESRI Products installed instead the API)
Anyone else?
Thanks in advance
Emiliano
by Anonymous User
Not applicable
I'm also getting this error.
EmilianoPetrelli
Do you have found a solution for this issue?
PhilLarkin1
I am also seeing this at 1.8.1
We recently upgraded our servers to 10.7.1
from arcgis.gis import server
url = r"https://<root>.<host>.org:<port>/arcgis/admin/"
site = server.Server(url,username=<user>,password=<pw>)
site.services
In  [99]:
Line 1:     admin = site.services
File C:\<...>\arcgispro-py3-clone\Lib\site-packages\arcgis\gis\server\_common\_base.py, in __getattr__:
Line 86:    raise AttributeError("'%s' object has no attribute '%s'" % (type(self).__name__, name))
AttributeError: 'Server' object has no attribute 'services'
ClintonBallandis1
I've also been getting 'Server' object has no attribute 'services'. I'm using ArcGIS Pro 2.5.0 and version 1.7.0 of the python API
I asked my colleague to try the same script using his ArcGIS Pro 2.6.1 and version 1.8.1 of the python api and there is no error.
