Make a field uneditable in a web Map doesn't work
474
11-16-2017 02:29 AM
AnthonyPhilibert
Hi, i create web map to show a feature service(a layer of point) with the python API to publish on arcgis online. I create  my web map specifiaction in a dictionnary as specified here. Everything is Ok except the part where you can specify which fields is uneditable. This parameter is defined in operationalLayers, popupInfo, fieldInfos and  isEditable for the fields you want to make uneditable.
My web map is published but the fields remain editable. Does anyone have the same problem and knows how to resolve it.
Tags (1)
