Using custom basemaps
1579
11-13-2017 12:17 PM
NachiChidambaram
I created a following basemap in arcgis online using mapbox : https://arcg.is/1zf5qz
I want to use this map as a basemap in my application.
I am trying to follow this example here ArcGIS API for JavaScript Sandbox
The mapBaseLayer urlTemplate  contains a  http://~xxx.png .  Not sure how to use the arcgis online custom maps in arcgis api 4.5
Do I need a png from arcgis online to use my map . If so can you provide an example ?
Tags (1)
ReneRubalcava
Esri Frequent Contributor
Basemaps are WebMaps, so you can add it like this.
  const map = new EsriMap({
    basemap: {
      portalItem: {
Here is a sample.
https://codepen.io/odoe/pen/EbvPPg
NachiChidambaram
I think i figured out the answer. Thanks . Will post it soon.
ReneRubalcava
    basemap: {
      portalItem: {
Here is a sample.
NachiChidambaram
How do I find the associated portalItem id ?
RobertScheitlin__GISP
Nachi,
  It is right in the url you have in your first post:
b74e3eeef31942869c1f611f341ce8ed
