AWS, DynamoDB and Geoprocessing
1197
10-25-2017 03:49 AM
SzymonPiskula
Hi
Documentation here:
AWS CloudFormation and ArcGIS—ArcGIS Enterprise on AWS | ArcGIS Enterprise
Says:
Configuration store
When you use Amazon S3 and DynamoDB for your configuration store, most services will be highly available with the following exceptions:
  • Geoprocessing services cannot be made highly available.
Question:
Why is that? What is the technical reason that GP cannot be made highly available in this scenarion? What dependency can not be met in such setup by the GP? Or is it for Custom GP  tools only?
JonathanQuinn
Esri Notable Contributor
I believe the problem is that the jobs directory has to be on disk to store the scratch.gdb, pdf, and other outputs.  The file server that will store the jobs directory won't be highly available as it's simply a file server.  I'm not sure what the highly available storage options are in AWS, (other than S3 and DynamoDB, of course).
