JSON Change Background of Widget Button
5171
11
10-20-2017 01:39 PM
Lake_Worth_BeachAdmin
Whats the config to change the widget buttons background color (not the icon).
RobertScheitlin__GISP
Joe,
   There will be no documentation on css customization.  Add these css rules to your apps theme common.css
(i.e. [install dir]\server\apps\[app#]\themes\FoldableTheme\common.css):
.jimu-widget-zoomslider,
.jimu-widget-homebutton,
.jimu-widget-mylocation,
.jimu-widget-homebutton.inHome,
.jimu-widget-homebutton .HomeButton .home,
.jimu-widget-homebutton.inHome .HomeButton .home{
  background-color: rgb(88, 100, 116);
  -ms-filter: "Alpha(opacity=50)";
  background-color: rgba(88, 100, 116, 0.5);
.jimu-widget-zoomslider:hover,
.jimu-widget-homebutton:hover,
.jimu-widget-mylocation:hover,
.jimu-widget-homebutton.inHome:hover .HomeButton .home {
  -ms-filter: "Alpha(opacity=70)";
  background-color: rgba(88, 100, 116, 0.7);
.jimu-widget-onscreen-icon {
  position: absolute;
  cursor: pointer;
  border-radius: 4px;
  -ms-filter: "Alpha(opacity=20)";
  background-color: rgba(88, 100, 116, 0.2);
.jimu-widget-onscreen-icon.jimu-state-selected {
  -ms-filter: "Alpha(opacity=80)";
    background-color: rgba(88, 100, 116, 0.8);
.jimu-widget-onscreen-icon:hover{
  -ms-filter: "Alpha(opacity=40)";
  background-color: rgba(88, 100, 116, 0.4);
Joe,
   I need a little more detail. Are you talking on Screen widget buttons or buttons in a controller widget like the HeaderController? BTW there is no way to do this in the config file it is a css rule that has to be added.
Is app builder developer required then?
I mean these widgets
Joe,
  Yes WAB Dev would be required to change those background colors. It is a simple css rule fix but not something you can do using AGOL version of WAB.
can you point me to docs or show an example of this CSS rule/syntax?
Joe,
  position: absolute;
  cursor: pointer;
  border-radius: 4px;
thank you sir
Is there a way to control this in AGOL Assistant with JSON? I saw a video somewhere about this I think but can't find it any longer.
Not that I am aware of.
GeorgeKatsambas
I want to change these widgets background color in WAB 2.10, I add this text
position: absolute;
cursor: pointer;
border-radius: 4px;
to the common.css under app # themes/foldable themes which changes it to a blank color. If I wanted a blue background for example would it be the same file I change. Not the home and zoom but my widgets or all if necessary.
