Custom Geocoders in Explorer on iOS
862
10-20-2017 08:12 AM
GarethBaker1
From what I can tell the only options for searching in Explorer are to use the pre-configured ESRI world geocoder or set up searching on layers in the web map.  Are there any plans to enable us to bring in geocoder services that are configured in our Portal/ArcGIS Enterprise?
by Anonymous User
Not applicable
Hey Gareth Baker‌,
Thank you for using Explorer. In the current implementation, Explorer can search via feature search (by layers) or by using the top geocoder set-up in the Portal/Enterprise. If you re-order your geocoder services so the custom geocoder is on top of the geocoder list, Explorer will use this for it's searches.
There has been an enhancement request to give users the option to select which geocoding service they would like to search from. If you'd like to follow this request you can contact support and ask to get attached to the ticket (ENH-000098923).
Joel
by Anonymous User
Not applicable
Hey Gareth Baker‌,
Joel
GarethBaker1
Thanks for the speedy reply Joel. That makes a bit more sense to me now.  There are actually about four or five geocoders that it would be useful to use in Explorer so it would be good to be able to allow more than just the one. I guess we could build a composite locator which wraps up all the others but I think for now we can make it work with a combination of feature search and the top geocoder.
