Table Not Editable !!!
17581
6
10-12-2017 09:51 AM
HossameldinElalkamy
I am adding a field to a feature layer in a geodatabase using AddField in Model builder but I am returned wit the error message "
ERROR 000499: table is not editable.
When I try to manually edit the same layer using start editing it is editable. I checked for Locks on the geodatabase and there are no lock files on that work space. I wonder if any body can help resolving this problem
Hossam
HossameldinElalkamy
I figured out whats the problem. It was that this layer is joined to another table. Removing the join solves the problem and addField in the model works fine. Thank you all.
SarojThapa1
Hossameldin,
Check the link provided below.
000499: Table is not editable.—Help | ArcGIS Desktop
Hopefully, it helps you.
KevinDunlop
Are you trying to edit the feature class while adding fields?  This will prevent you from adding it.  Fields can only be added outside an edit session.
Lake_Worth_BeachAdmin
Kevin is correct, stop the edit session, add the field then start the edit session again.
HossameldinElalkamy
No the workspace is not open for editing while trying to add the field programmatically in the model. It is not the issue. Thank you.
HossameldinElalkamy
LilingLyu
I just had the same issue, didnt have any join tables. Simply just save the file, close and reopen ArcGIS.
Sometimes it does funny things.
