Create Scene Layer Package Failure
3104
10-10-2017 02:05 PM
YaneevGolombek
Hi All,
I am attempting to create a "Scene Layer Package with a 180mb lidar data set with the hope of publishing the data to ArcGIS online. However, I get a "Failed to Compress data using method [2] error. a clip of the error is below. Any ideas why I am getting this error. Using ArcGIS Pro 2.0.
Thanks.
Jacob_FougstrupNicolajsen3
Any solution to this? I get a similar error:
Error
Andrew--Johnson
Are you able to share one of the lidar datasets so I can take a deeper look at this on our end?
Andrew--Johnson
Looks like it may be the custom vertical coordinate system that is causing the problem. I'm going to have our developer debug this further to get the exact cause. I was able to successfully run the tool by creating a prj file for the LAS which overrides the coordinate system in the header of the LAS. Here is the prj file that i used
https://www.arcgis.com/home/item.html?id=178899bc2e2f423baedae57bf29c3bbb
Go ahead and place that with the LAS file and let me know if it works for you.
