Adding related records in Web AppBuilder.
10609
22
10-06-2017 06:00 AM
RyanPurdy
I am following the instructions on this link: Edit widget—Web AppBuilder for ArcGIS | ArcGIS
When I open my app I don't see a pencil icon next to the related table that I should see in instruction 1 (d).  I have a right arrow that only allows me to see the related record and then edit it. There aren't any options to add a related record.  Is there something I am missing?
RobertScheitlin__GISP
Ryan,
   Is your related data published as a FeatureServer service and does it allow for edits?
RyanPurdy
I believe so.  Here are the settings.
Ryan,
   Is that for the parent data or the related data?
RyanPurdy
They are the settings for the feature layer.  Is that just for the parent data?  I attached a screenshot of where I go to see the settings.
That is just the parent data. You are wanting to edit the relayed data so you need to check the edit permissions on those layers
RyanPurdy
Robert where would I find those permissions?  Under the tables I don't see an option.  I went back in to the app and I can edit records in related tables I just can't add records.
Ryan,
   Go to the tables service url link and see if the service url has
Capabilities: Create,Delete,Query,Update,Uploads,Editing
RyanPurdy
This is the link:
https://services.arcgis.com/q3mIlR87lZlZsds3/arcgis/rest/services/Current_2017_10_2_v2/FeatureServer...
When I scroll to the bottom it does show Add Records as a supported operation.
Ryan,
  I am out of suggestions then. It looks like it is time for you to call esri tech support on this issue.
