Reduced Widget Choices
1018
09-14-2017 12:38 PM
JoelThomas
I was wondering why when I log onto Portal as a publisher, I have a reduced lot of widgets to choose from. For instance, the query widget is very basic and doesn't allow for spatial queries or the ability to export to csv. Do i have to be using developer edition to get the expanded widget choices?
Compare the screen shots below:
This is a basic widget listing I get when I log into portal.
This is a basic widget listing that I get making a web app in portal.
I have a different account that allows me all the following widget choices. Note the query widget is different (more robust). Why am I being reduced in the above account, but have more choices below ??
Tags (1)
RobertScheitlin__GISP
Joel,
   The difference is that Portal is one or more versions behind AGOL WAB (and developer) depending on the version of Portal you are using.
Joel,
JoelThomas
Ah, that makes sense. We're using portal 10.3
That equates to a WAB version that is three versions behind the current WAB.
Don't forget to mark this question as answered.
