"Failed to create the app" While creating app from WAB 2.5
4668
8
09-07-2017 06:31 AM
ShaikhRizuan
I have registered my Web AppBuilder with the portal which is joined with another portal (Portal A as Primary and Portal B as StandBy). Both portal server are configured to a single Web Adapter and don't have internet connectivity.ArcGIS javascript API 3.21 configured locally and "env.js" file configured accordingly for WAB 2.5.
While creating the 2D App (After entering Title & description and click on "OK" button, I am getting the error "Failed to Create the app".
Create app error
while debugging I found that the error was coming from "arcgis_web_appbuilder_2.5\WebAppBuilderForArcGIS\client\stemapp\jimu.js\portalUtils.js". It was throwing error on "getDefaultWebMap" function (Line No: 1213) . Where "id" is coming "Undefiend"
Error at portalUtils.js
I am not able to figure it out, why it is not generating "id" from the above function.
Kindly anyone help me on this!!!
(Note: Also attached above two images separately)
Regards,
Shaikh Rizuan
KierenTinning2
Just wondering if you have resolved this issue.  I am running into the same problem, we've tried WAB 2.4 and 2.5.  Interestingly we can create 3D apps to our hearts delight, just not 2D apps.
RobertScheitlin__GISP
Kieren,
   The workaround fix for this in the past has been to continue to click the OK button until it finally works (it may take clicking a bunch of times).
KierenTinning2
Thanks, I saw that and clicked about 10 times, finger got sore 🙂
It's just odd, because it creates 3D apps just fine.
I have seen it take more than 10. keep clciking
ShaikhRizuan
Hi Robert,
You have suggested in one of the threads, I read and clicked more than 100 times...  but no luck.
One thing I notice that, In Portal, Though i am connected to internet but i am not able to see basemap gallery from the map viewer. The above function is looking for ArcGIS portal ID, Which is not generating.
Kindly help me on this.
@ Kieren: I could able to create 3D apps but not 2D apps and still not able to fix the issue.
If that workaround does not work for you then you just need to delete the whole WAB Dev app and start over.
ShaikhRizuan
That also done... but not luck
KierenTinning2
Shaikh,
We have done the same.  Trouble shooting continues
