arcgis server 10.5 web adaptor for portal
1140
08-30-2017 07:24 AM
youngpark
New Contributor III
Good morning,
I have a simple question about web adaptor setting for my new arcgis portal.
In a machine(AWS), I installed Arcgis Server 10.5, Portal 10.5, GeoEvent server 10.5, web adaptor 10.5 (arcgis/portal)
I can access the server (server manager with web adaptor, geoevent without web adaptor) from a different network.  Unfortunately, not the portal site.
Question is as follows.
  1. I was able to setup web adaptor for ArcGIS server then, I can access to the manager site https://xxxxx/arcgis/manager from a different network. I could not configure web adaptor(arcgis) for Portal.  When I select the PORTAL, server returns HTTP 400 error.
    Thus I created an additional web adaptor (portal), however, I am getting the same error.
    And, I can access to portal site with port number from the server.  However cannot access to the port site from a different network.  It will redirect the “address from domain.name:7080/arcgis/home” to “computer.name:7080/arcgis/home”
If you have any suggestions please guide me to the right direction.
JonathanQuinn
Esri Notable Contributor
You should be using two separate web adaptors, (arcgis for Server and portal for Portal, for example):
Can I configure the same ArcGIS Web Adaptor to work with both ArcGIS Server and Portal for ArcGIS?
So when you install the portal web adaptor, reaching https://<machine>.<domain>.com/portal/webadaptor returns a 400?
youngpark
New Contributor III
hi Jonathan,
I do understand i cannot share the web adaptor for the portal and the gis server.  when I access to " https://<machine>.<domain>.com/portal/webadaptor"  my browser cannot find the page at all.
http://machinename/portal/webadaptor returns the web adaptor setting page, but I am getting the 404 error when I select the "portal".
https://machinename/portal/webadaptor returns following message "The web adaptor configuration URL has to be accessed from the machine hosting the web adaptor."
thanks in advance,
Young
