How to get ArcGIS Online Basemaps into MMPK?
27791
50
07-17-2017 12:44 AM
KarlW
With the latest version of the Explorer for ArcGIS app, offline access is via an mobile map package (*.mmpk) which is great but I get an error (The layer type is not supported in runtime content) when I try to add an ArcGIS Online basemap to my MMPK.
How do I get ArcGIS Online basemaps into my MMPK much like the old offline cache method can with Collector for ArcGIS?
Karl
MarkBockenhauer
Karl,
At this time it is not possible to put online content directly into a Mobile Map Package.  ArcGIS Pro 2.0 only supports writing file based vector data (File Geodatabase, Shapefile and Vector Tile Packages) into a Mobile Map Package.  For Pro 2.1 we are working on adding raster support (File and TPK) and leveraging ArcGIS Online Vector Tile basemaps.
Which ArcGIS Online basemap are you most interested in using in Explorer?
Mark
DanPatterson_Retired
The list of files that is supported and the restrictions as to where those files need to reside in order to be included is listed here http://pro.arcgis.com/en/pro-app/tool-reference/data-management/create-mobile-map-package.htm
I suspect the restrictions are the reason
KarlW
Hi Dan,
I've read the numerous help pages but none make it clear that AGO base maps are not supported. Why boobytrap Explorer for ArcGIS like this? #ItShouldn'tBeThisHard
Cheers,
Karl
shan_sarkar
Karl,
Is your requirement specific for .mmpk, will a .tpk suffice?
~Shan
~Shan
KarlW
MarkBockenhauer
Karl,
Mark
shan_sarkar
I agree with Mark here, as we speak of the current version of ArcGIS Pro does not support a raster layer while creating an .mmpk file. This is the reason why I asked if a .tpk would suffice your need.
Refer https://community.esri.com/thread/127722
I hope this helps!.
~Shan
~Shan
KarlW
Hi Mark,
We need the imagery with labels base map to provide context for our vector layers.
So the Explorer for ArcGIS app can only go offline with file-based vector data. This is a serious limitation for us so will have to use Collector for ArcGIS and traditional offline workflow for the time being.
We look forward to ArcGIS Pro 2.1.
Karl
mohsenvakilpour
Hi Mark,
I tried to create .mmpk using ArcGIS Pro 2.1 Beta2 also, but i get error this message again: "The layer type is not supported in runtime content:" when i add an imagery layer (It was WMS online tile service).
So please let me know How we can add an imagery basemap whenever we use .mmpk file in our app?
MarkBockenhauer
Mohsen,
Only file based rasters (Tile Packages .TPK and .JPG, .PNG etc..) are supported for inclusion in a Mobile Map package, WMS services are not supported.
Keep in mind that the current release of Explorer does not support Mobile Map Packages that contain raster layers.  Explorer for ArcGIS with support for raster layers in a mobile map package, will be available when the ArcGIS Pro 2.1 final release is public.
Mark
