call google api as a function in my search widget
3506
07-09-2017 06:38 AM
Henryobaseki
Hi All,
Do not know if anyone has worked with Google places api or OSplaces api.all similar to Esri javascript api.
I would like to include Google search places api as a function or sources in my search widget code. Don't really know the best way to go about this though.
Google Api search function
https://developers.google.com/maps/documentation/javascript/examples/geocoding-simple
<script>
function initMap() {
var map = new google.maps.Map(document.getElementById('map'), {
          zoom
: 8,
          center
: {lat: -34.397, lng: 150.644}
var geocoder = new google.maps.Geocoder();
        document
.getElementById('submit').addEventListener('click', function() {
          geocodeAddress
(geocoder, map);
function geocodeAddress(geocoder, resultsMap) {
var address = document.getElementById('address').value;
        geocoder
.geocode({'address': address}, function(results, status) {
if (status === 'OK') {
            resultsMap
.setCenter(results[0].geometry.location);
var marker = new google.maps.Marker({
              map
: resultsMap,
              position
: results[0].geometry.location
} else {
            alert
('Geocode was not successful for the following reason: ' + status);
</script
I want the google search api to carry out the address searches when a user click on a search button to search a post code for example but I want the search result to be displaced on ESri map.
How do I include google api search to the searchWidget sample below
ESRI Search Widget( its also a geocoding service on its own)
<script>
    require([
      "esri/Map",
      "esri/views/SceneView",
      "esri/widgets/Search",
      "dojo/domReady!"
    ], function(
      Map,
      SceneView,
      Search) {
      var map = new Map({
        basemap: "satellite",
        ground: "world-elevation"
      var view = new SceneView({
        scale: 123456789,
        container: "viewDiv",
        map: map
      var searchWidget = new Search({
        view: view
      // Add the search widget to the very top left corner of the view
      view.ui.add(searchWidget, {
        position: "top-left",
        index: 0
  </script>
The other option will be to the  search widget multiple sources option, how do I call the google api function on its on without including google map function initMap.
Thanks for all your help...
Henryobaseki
Hi All
It just tool complicated to use external service within Esri JavaScript API. I have opted for Esri geocoding service instead it gives me what I need an xy coordinates with addresses.
Thanks...
ThomasSolow
You should be able to use google's API without pulling anything in from google.  It's been a while since I've used a google API but a quick search led me to a couple sample URLs:
https://maps.googleapis.com/maps/api/geocode/json?latlng=40.714224,-73.961452&key=YOUR_API_KEY
https://maps.googleapis.com/maps/api/geocode/json?address=1600+Amphitheatre+Parkway,+Mountain+View,+CA&key=YOUR_API_KEY
(source)
You can make requests in these formats using an XHR, or whichever wrapper your prefer (esri/request is an option since you're pulling in the Esri JS API) and get back a list of results, which you can then display how you choose.
I recommend creating your own search widget: you can add a text box, search button, and a place to display results.
Henryobaseki
The json format you showed is for one entity or location.
I do have a search widget jean Marc Roy helped with this; see link below
https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fplnkr.co%2Fedit%2FcJr3F4OWjVeseUf8Lj...
Searches coming from different featureservers.
var featureSource1 = new FeatureLayer({
   url: "https://services7.arcgis.com/uE69mPI6U3rpSmCT/arcgis/rest/services/aAdd_csv/FeatureServer/0",
   popupTemplate: { // autocasts as new popupTemplate()
    title: "Post Code: ${Postcode}</br>UPRN: ${UPRN}</br>ADDRESS: ${ADDRESS}",
    overwriteActions: true
  var featureSource2 = new FeatureLayer({
   url: "https://services7.arcgis.com/uE69mPI6U3rpSmCT/arcgis/rest/services/postcodesS/FeatureServer/0",
    title: "Post Code: ${Postcode_3}</br>Wards Name: ${Ward_Name}</br>Ward: ${Ward_Code}",
I would like my third source, if possible would like the only source to come from googleApi. I guess when a user types in an address in the search it returns the json format as a lookup and then displaces it on the map.
here is my google map key
https://maps.googleapis.com/maps/api/geocode/json?address=1600+Amphitheatre+Parkway,+Mountain+View,+...
Thanks in advance
Henryobaseki
Hi All
Thanks...
