Search Widget Mulitple sources in 4.4
1255
07-25-2017 01:53 PM
Henryobaseki
Hi All,
I m trying to use to search widget to search addresses from Esri geocoding service and also from two layer. Similar to the sample in 3.21https://developers.arcgis.com/javascript/3/jssamples/search_multiplesources.html
I have added the locator with the  two feature Layers and doesn't seem to be working. Thanks in advance
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Search Widget 3D - 4.4</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <script src="https://js.arcgis.com/4.4/"></script>
  <script>
require([
  "esri/Map",
  "esri/views/SceneView",
  "esri/widgets/Search",
  "esri/layers/FeatureLayer",
  "esri/symbols/PictureMarkerSymbol",
  "esri/config",
  "dojo/domReady!"
], function (
  Map,
  SceneView,
  Search, FeatureLayer, PictureMarkerSymbol, esriConfig) {
    esriConfig.request.corsEnabledServers.push("cdn4.iconfinder.com");
    var map = new Map({
      basemap: "satellite",
      ground: "world-elevation"
    var view = new SceneView({
      scale: 123456789,
      container: "viewDiv",
      map: map
     var locatorUrl = new Locator({
      popupTemplate: { // autocasts as new popupTemplate()
        title: "Post Code: ${Postcode}</br>UPRN: ${UPRN}</br>ADDRESS: ${ADDRESS}",
          overwriteActions: true
    var featureSource1 = new FeatureLayer({
    var featureSource2 = new FeatureLayer({
        title: "Post Code: ${Postcode_3}</br>Wards Name: ${Ward_Name}</br>Ward: ${Ward_Code}",
    var searchWidget = new Search({
      view: view,
      sources: [
              //Pass in the custom locator to the sources
              locator: new Locator(locatorUrl),
              singleLineFieldName: "DataID",
              outFields: ["Match_addr"],
              //Create an InfoTemplate
              infoTemplate: new InfoTemplate("DataID", "ID: ${Match_addr}")
          featureLayer: featureSource1,
          searchFields: ["Postcode", "UPRN"],
          displayField: "Postcode",
          exactMatch: false,
          outFields: ["*"],
          placeholder: "example:  CM2 0HU",
          resultSymbol: new PictureMarkerSymbol({
            height: 36,
            width: 36
          featureLayer: featureSource2,
          searchFields: ["Postcode_3", "Ward_Name"],
          exactMatch: false,
          displayField: "Postcode_3",
          placeholder: "example: ...",
          outFields: ["*"]
    console.log(document.getElementById("submitButton"))
    document.getElementById("submitButton").onclick = (e) => {
      e.preventDefault()
      let el = document.getElementById("input")
      console.log(el.value)
      searchWidget.search(el.value).then((result) => {
        console.log("result", result)
  </script>
</head>
<body>
  <div>
    <form>
      <input placeholder="Enter your address" type="text" id="input">
      <button id="submitButton">Submit</button>
    </form>
  </div>
  <div id="viewDiv"></div>
</body>
</html>
Tags (1)
Henryobaseki
Hi All,
Figured how it works pretty similar to the 3,21. Tested the code in 4.4 and it works!
Thank you
Henryobaseki
Hi All,
Thank you
