Select by Attribute fails using Python Layer Object in Standalone script
1165
05-31-2017 08:33 AM
IanMurray
Honored Contributor
How a script can work within a map document python interpreter but fail as a standalone script has puzzled me several times and I usually find a way to work around it.  This one though I want answers to.
I have simplified a part of a much larger script to indicate the issue I am having, all I want to do is select all the features within the current map extent(I need a count of them, so I use this with GetCount).  Since Select By Attribute works with the Extent Environmental variable, I figured that was the easiest way to do it.  When running with the python interpreter in a map document, this script works fine.
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
Layer2 = arcpy.mapping.ListLayers(mxd, "USA City Populations")[0]
df = arcpy.mapping.ListDataFrames(mxd)[0]
arcpy.env.extent = df.extent
arcpy.SelectLayerByAttribute_management(Layer2)
It select all the features in my dataframe extent as I want.  However, I want to run this as a standalone, only changing the mxd to the file path of the map document instead of the "CURRENT" key word it fails.
ExecuteError: ERROR 000358: Invalid expression
Failed to execute (SelectLayerByAttribute).
Select By Attribute is supposed to be able to work with TOC Layers, so I don't see why there is an issue using a Layer Object.  I've also attempted this with the Layer Name as it appears in the TOC hard-coded in as the input for SelectLayerByAttribute.  Again this works fine when run within the map document with the python interpreter and using the "CURRENT" Keyword but fails as a standalone with the map document path hard coded in.  I know the workaround is just to make a Feature Layer, but I want to understand why this simple code won't work standalone but will within the python interpreter.
IanMurray
Honored Contributor
I figured it out, problem with a bad definition query.
DanPatterson_Retired
if it is totally offline, I am not sure why you would want to work with a dataframe.  In any event, an in arcmap can become a *.lyr for use out of arcmap, it references the data and contains the symbology
IanMurray
Honored Contributor
It is part of a larger script that will eventually export the map to a pdf.  I need to get the count of the features in the current map extent for that layer then change the definition query depending on the count.
JoshuaBixby
MVP Esteemed Contributor
What version are you running?  I am running 10.5, and I just tried to recreate your problem using an MXD and I could not.  I am not sure if I didn't set everything up the same as you or if something else is going on.
Does you map layer have a definition query? What type of data store is the layer in, file geodatabase?
IanMurray
Honored Contributor
