Web appbuilder error: "server" directory not found
5780
7
05-30-2017 08:45 PM
AbhayDuvvuri2
I have extracted the latest version of Web Appbuilder into my C:\.
I am executing the startup.bat from "C:\WebAppBuilderForArcGIS" but I get he following error:
"Server" directory not found.
Please let me know in case I missed anything.
JayantaPoddar
Ensure the zipped file is fully downloaded. Do you See Server sub-folder inside the WebAppBuilderForArcGIS folder?
WAB
Think Location
AbhayDuvvuri2
server folder
Thanks for the immediate response. I have the fully downloaded version. Please let me know in case I missed anything.
AbhayDuvvuri2
The IT policy within the organization was blocking NODE_X64 to be executed and then I tried with administrative previlges whihc gave the "server" not found error.
The issue has been resolved once IT have updated the policy.
Thank you.
DanCronin
Thanks for this thread Abhay, and Jayanta for your response.
I also had this problem. Our IT identified it a firewall issue. We didn't verify that because it worked when I set up WAB as a Windows service as per the following instructions. Hope this workaround helps someone.
https://developers.arcgis.com/web-appbuilder/guide/getstarted-run-as-window-service.htm
Cheers
pontiff76
@DanCronin Where should I install the Node.js file at?
pontiff76
Which policy is it? I encounter the same problem.
tchaulla
Thanks Jayanta! That worked for me. I wonder why the server sub-folder didn't download the first time. Regardless, I tried it again and it worked.
