How to set a default value for edit widget field dynamically
2246
05-28-2017 09:14 PM
AlistairFox
I have a web app builder project that has an editable layer in it. The project ID is being based to the web app through the URL. I can grab this in javascript and use it. What I'd like to do is set the default value for the projectid field that is written by the edit widget when a new record is created.
any pointers on where in the edit widget code I can intercept where the values are written and returned to the feature service?
RobertScheitlin__GISP
Alistar,
  You can do that by modifying the edit widget _worksAfterCreate function:
     _worksAfterCreate: function(AddrPt2) {
        // add close button to atiInspector
        this._addButtonToInspector();
        // resize editPopup
        this.editPopup.resize(500, 251);
        // update templatePicker for responsive.
        this.editor.templatePicker.update();
//Add the autopopulate field value
        this.editor.templatePicker.on("selection-change", lang.hitch(this, function() {
          var selected = this.editor.templatePicker.getSelected();
          if (selected) {
            var featureLayer = selected.featureLayer;
            on.once(featureLayer, "before-apply-edits", lang.hitch(this, function(evt){
              if(evt.adds && evt.adds.length > 0){
                if(evt.adds[0].attributes.hasOwnProperty('ADDRESS')){
                evt.adds[0].attributes.ADDRESS = AddrPt2;
                this.editor.attributeInspector.refresh();
  //End add‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Alistar,
        // resize editPopup
          if (selected) {
ArcGisServerPj
Hi. I have the same   issue. I don’t known where to put this function worksAfterCreate. I need your help.
