Arcmap 10.5 crashes when using Toolbox
8538
8
05-09-2017 01:46 PM
SusanPenacho1
I have arcgis 10.5 desktop on my windows 10 machine. I tried uninstalling arcgis 10.5 and python and reinstalling but the problem persists. Any ideas on how to fix?
RebeccaStrauch__GISP
Start with steps in this https://community.esri.com/docs/DOC-2121?sr=search&searchId=cd6a211a-a246-4fe0-8698-e9e9f38eaf2d&sea...‌    It's amazing how those steps can fix many "now it crashes desktop" issues.
Windows 10 can have a few other quirks, but see if the above works first.
JayantaPoddar
If the solution steps provided by Rebecca doesn't work, you could disable background geoprocessing. Sometimes, it causes the issue as well.
Foreground and background processing—Help | ArcGIS for Desktop
Also I have seen a fresh install of Windows 10 gives fewer issues with ArcGIS than those upgraded from older versions.
Think Location
SusanPenacho1
Unchecking the background geoprocessing worked and now the program has stopped crashing. However, I still can not use the Search window in arcmap though it does open in arccatalog. When I click on the search window nothing happens.
JayantaPoddar
Check Problem: The Search window in ArcMap does not return any results .
Are you facing the same issue?
Think Location
SusanPenacho1
That's not quite the problem. I can not even open the search window (either by clicking on the icon or going under windows>Search or the shortcut ctrl+F). I tried option b (since I can't get to the search options under option a) and still could not open the search window after renaming the catid folder.
JayantaPoddar
Resetting your ArcGIS application profile usually resolves this kind of issues. Ensure all ArcGIS Desktop applications are closed before you proceed with resetting the ArcGIS application profile.
Also rename the ESRI folder in the registry to ESRI_OLD.
The folder may be located in HKEY_CURRENT_USER\Software\ESRI
Think Location
SusanPenacho1
I did all those rest items and it did not fix the issue. I still cannot open the search window in arcmap though it does still work in arccatalog though its slow to open
DanPatterson_Retired
try a repair... start control panel and look for 'uninstall' which will get you to this dialog, right-click on arcgis
Then proceed from there
