Drop options from single select as they are selected?
2421
02-08-2017 02:11 PM
TL2
I would like to have a list of options.  As they are selected, the list gets smaller until there are none left.  This would be in a repeat with a specified number of records with the same number of options to select?
Is there a way to do this either behind the scenes in S123 Connect or even calculated on the fly in hidden fields behind the scene?
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
This currently isn't supported in Survey123 for ArcGIS- currently only equality expressions are supported.  I've logged this as an enhancement to support.
Nicole_Ueberschär
In case someone is stumbling over this question: You can solve this by put for question2 in the choice filter not(selected(${question1},opt)) and column opt in the choices sheet with the same values as in opt. Tested with select_multiple only but don't see why it shouldn't work for select_one questions.
