popup - how to fetch the query result after the popup appears on view click event
4685
8
02-01-2017 03:32 AM
LaxmanThapa
  1. I have a webmap attached to a view.
  2. Now when ever a view is clicked, a default popup appears over the map.
  3. After the popup has been added, a query is called automatically to load the features
  4. I need to get the result of this query.
How can I get the result, so that I can use the result data. I cannot see any event related to the query nor the popup object to get the result.  I am using js ver 4.2 btw.
FC_Basson
You should be able to get the query feature with view.popup.features and then iterate through the features returned to get the attributes.
LaxmanThapa
But how to trigger the callback function? How do I know when the query request has completed ?
FC_Basson
Event handler?
view.popup.on("open", function(evt){
// code
LaxmanThapa
Hi Basson, thanks for the quick reply but your code didnot help.
The event 'open' doesnot fire..
FC_Basson
Sorry, no time to test.
LaxmanThapa
I tried to add a popup template  for the layer like
var popupTemplate = new PopupTemplate({
    title: "Régions Industrielles 2017: {NOM}",
    content: setContentInfo
function setContentInfo(feature){
    console.log(feature)
    return "?? no idea what the original template is....";
//later added this template to the layer
lyr.popupTemplate = popupTemplate;
Now I can access the query feature, but now I do not know the 'content' template for the popup.
EvelynHernandez
Hello there, here comes an example :
var myTitle = "Hello";
var sum1  ="there";
var point = feature.attributes.geometry;
var content = `<div style=padding-top: 10px;>Title: ${myTitle}<br /></div>
 <div style=padding-top: 10px;>Sum1: ${sum1}<br /></div>`;
map.infoWindow.resize(450, 250);
 map.infoWindow.setContent(esri.substitute(esri.geometry.webMercatorToGeographic(point), content));
LaxmanThapa
Also, there is no event 'open' for the view.popup @ api reference Popup | API Reference | ArcGIS API for JavaScript 4.2
