Modify Popup Template for Video from url in attribute table
1997
01-25-2017 05:52 AM
RuthCostley4
I am trying to modify the code found at https://community.esri.com/thread/121245 to use a text field from the attribute table of the layer for the URL of the video. I am new to Javascript, so I'm struggling. I need to change line 7 so that the src is text from my attribute table. thx...
  1.  var template  = new PopupTemplate();
  2.         template.setTitle("<b>City</b>");
  3.         template.setContent(getContent); //this will call the getContent function where you can custom build your fields and add video
  4.
  5.         function getContent(graphic){
  6.           var Content = "<b>City Name:  </b>" + graphic.attributes.areaname + "<br> <b>Population:  </b>" + graphic.attributes.pop2000 + "<br>";
  7.           var Hyperlink = '<video width="250" height="250" controls><source src=http://techslides.com/demos/sample-videos/small.mp4 type=video/mp4></video> ';
  8.
  9.           return Content + Hyperlink;
  10.         }
RobertScheitlin__GISP
Ruth,
   You are using an attribute already from data in that method "pop2000" so it is not much different:
          var Hyperlink = '<video width="250" height="250" controls><source src=' + graphic.attributes.videourl + ' type=video/mp4></video> ';
RuthCostley4
Thanks!!!
Ruth,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
