Javascript API - Show Video Feed in Popup?
13832
10
02-05-2015 06:33 AM
chuckfrank
Hi All,
Is it possible to show a live streaming video feed in a map popup using the javascript api?  I thought there used to be an example, but maybe that was for the flex api.  Anyhow, I'd like to be able to click on a map point and bring up a live video stream that is coming from a camera at the location.  If this isn't possible, are there alternatives to using a popup?
Chuck
JakeSkinner
Esri Esteemed Contributor
Here is a quick example of embedding a video within a Popup.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Sample Map</title>
    <!--<link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">-->
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/dijit/PopupTemplate",
        "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, PopupTemplate,
        dom, on, array
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        var template  = new PopupTemplate();
        template.setTitle("<b>City</b>");
        template.setContent(getContent); //this will call the getContent function where you can custom build your fields and add video
        function getContent(graphic){
          var Content = "<b>City Name:  </b>" + graphic.attributes.areaname + "<br> <b>Population:  </b>" + graphic.attributes.pop2000 + "<br>";
          var Hyperlink = '<video width="250" height="250" controls><source src=http://techslides.com/demos/sample-videos/small.mp4 type=video/mp4></video> ';
          return Content + Hyperlink;
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",{
            mode: FeatureLayer.MODE_ONDEMAND,
            infoTemplate: template,
            outFields: ["*"]
        map.addLayer(featureLayer);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
JakeSkinner
chuckfrank
Hi Jake,
I'm downloading this sample but haven't been able to get it to run.  Do you know if there is a problem with it?
Custom info window | ArcGIS API for JavaScript
Chuck
TimWitt2
chuck,
this sample is using a module, which you are missing.
See this part of the code:
var dojoConfig = {
        parseOnLoad
:true,
        packages
"name": "myModules",
"location": location.pathname.replace(/\/[^/]+$/, "") + "/myModules"
Tim
chuckfrank
Hi Tim,
I must have something set up wrong.  I downloaded the sample and have the "myModule" folder at the same level as index.html.  When I view the source it appears to be looking in the right place.  Do I need to change any code?
Chuck
chuckfrank
Trying different browsers, I'm getting this to work in Firefox but not Chrome or IE 11.
JakeSkinner
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      require([
      ], function(
        dom, on, array
          basemap: "streets",
          zoom: 8
            outFields: ["*"]
    </script>
  </head>
  <body>
  </body>
</html>
chuckfrank
Thanks Jake!  This is a great example to get me going towards a live stream in a popup.  Thanks for your help.
TimWitt2
Chuck,
An alternative would be to have the video show in panel to the side of your map? Depending on which feature the user clicks the panel will populate with a different live feed?
Or check this out, doable with map tour story map: The Mackall Road Driving Tour
Tim
ShitalDhakal__GISP
Hi, I am just getting into scripting in Webapp builder. I am wondering where would I place the above scripting file? Or what file are you editing above?
Thanks in advance.
