DefinitionExpression with MapImageLayer subLayer
3365
01-10-2017 12:36 PM
RandyBonds_Jr_
I'm having trouble with a complex definitionExpression in a sublayer of my MapImageLayer (JSAPI 4.2). When I do the same query from the REST service directory, it works perfectly.
More or less, I want a date range and either of two other field values to be 1. What happens is that the points are all shown, but only the ones that match the query have a popup... it's really neat.
Here's my code
        var layer = new MapImageLayer({
          url: "https://gis.yakimawa.gov/arcgis101/rest/services/CouncilDistricts/ElementarySchoolSidewalksAnalysis/...",
          sublayers: [
            visible: true,
            definitionExpression: "Type = 1",
            popupTemplate: template
            visible: true
            visible: true,
            popupTemplate: streetTemplate
            visible: true,
            visible: false,
            definitionExpression: "(Collision_Date <= date '2016-12-31 23:59:59' AND Collision_Date >= date '2014-01-01 00:00:00') AND (Number_of_Pedestrians_Involved > 0 OR Number_of_Pedalcyclists_Involve > 0)",
            popupTemplate: collisionTemplate
KristianEkenes
Hi Randy,
This is a bug we weren't aware of. So thanks for asking about it.  This is actually already fixed for our next release. In the meantime you can use the following code to patch your app.
// TODO remove when upgrading to 4.3
function patchMapImageLayer(layer) {
  var original = layer.createExportImageParameters;
  layer.createExportImageParameters = function(options) {
    var params = original.call(layer, options);
    var layerDefs = params.layerDefs.split(";").reduce(function(result, layerDef) {
      var firstColon = layerDef.indexOf(":");
      var layerId = parseInt(layerDef.slice(0, firstColon));
      result[layerId] = layerDef.slice(firstColon + 1);
      return result
    params.layerDefs = JSON.stringify(layerDefs);
    return params;
patchMapImageLayer(layer);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Here's a small sample app using your layer, which shows it working as expected: JS Bin - Collaborative JavaScript Debugging
Be sure to remove this code once you upgrade to 4.3 since this will break the app. Hopefully that helps!
KristianEkenes
Hi Randy,
      return result
    return params;
RandyBonds_Jr_
Awesome! Thank a ton!
