Editor Tracking fields hidden in attributeinspector
2496
9
12-15-2016 12:59 PM
JeffPace
I am trying to display (but not edit) the editor tracking fields of a layer in a feature service.  If editor tracking is disabled in the database, they show up fine.
However if i enable editor tracking in the database, the fields disappear in the attribute inspector.  They exist in the data, and in the json response, they are just not shown.
Is there any way to display them? i have them set as isEditable = false;  in the code.
JeffPace
anyone? khutchins-esristaff
KellyHutchins
Esri Notable Contributor
I just ran a quick test and the editor tracking info shows up for me. Here's my test app:
http://www.arcgis.com/apps/View/index.html?appid=dc902a58c3d947b3b87fb04fd12d4550
JeffPace
Thanks for the reply,
 I get a cannot create map when i click on your link.
I made  a fiddle
Edit fiddle - JSFiddle
username:util
password:utilities
click on a blue dot, you will see some fields, but not the editor id fields.  Editorid is set in the database on, UTC time.
KellyHutchins
When I test your JSFiddle I can see the editor tracking info in the popup. Here's a screen shot showing what I see.
JeffPace
Exactly.  There should be six fields displaying.
{'fieldName': 'BUSINESS_N', 'isEditable': true},
{'fieldName': 'ADDRESS', 'isEditable': true},
{'fieldName': 'CREATOR', 'isEditable': false},
{'fieldName': 'CREATIONDATE', 'isEditable': false},
{'fieldName': 'EDITORNAME', 'isEditable': false},
{'fieldName': 'LASTUPDATE', 'isEditable': false},
JeffPace
If i make the lone change of disabling editor tracking in the database, the fields immediately show up in the attribute inspector
KellyHutchins
jeff.pace‌ I am pretty sure that this is by design. If you look at the image I shared you can see the editor date and owner info is displayed as text rather than an editable field. If editor tracking is enabled those fields will be auto populated based on the logged-in user and date/time.
JeffPace
Right, so we can see lastupdate and editorname.  I understand that, but what about creatorname and creation date?
KellyHutchins
Check out the getEditSummary help in the JSAPI. The attribute inspector uses this info to populate the editor tracking div.  There's some info that explains when you'll see the Created info.
FeatureLayer | API Reference | ArcGIS API for JavaScript 3.18
