How to query DTED offline using ArcGIS .Net SDK?
2907
12-08-2016 03:08 PM
NickCooper
Our application needs to do some elevation calculations (and is not connected to the internet), as a result we need to determine the highest elevation for a given polygon. How can we query DTED offline using ArcGIS .Net SDK?
Option 1 - Use Esri.ArcGISRuntime.Controls.FileElevationSource
So in order to use FileElevationSource it turns out it must be associated with a SceneView. We were only using a MapView so I added in a SceneVeiw and associated the FileElevationSource
sceneView.Scene.Surface.Add(elevationSource);W
When I tired to access the elevation source I get an AccessViolation
elevationSource.GetElevationAsync(location as MapPoint).Result
Option 2 - Some how use LocalServer
The doco states that ArcGIS Runtime LocalServer support a number of Raster formats including DTED.
Local Server raster support—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
So I use ArcMap to create a map package file with the DTED files within but have no idea how to use Local Sever to query the package file
Ultimately we want to:
1) Load a number of DTED files
2) Query for a given lat/lon what the elevation is at that point
Any help would be greatly appreciated!
Note we are using .Net Runtime SDK v10.2.7
KeithGemeinhart1
I have similar goals but we are using v100.0 (Quartz). Did you ever figure this one out?
EricBoice
I have a similar if not the exact same error "AccessViolation" when using the GetElevationAsync funciton.  Has anyone had any luck resolving this Error?
Here are my current post on my error and the access violation i was having.  We only see this issue when we are using prism and the SceneView is in its own module.  With a stand alone wpf application the GetElevationAsync funtion call works fine.
access violation with GetElevationAsync(mapPoint) when using Prism
c# - Prism and Esri GetElevationAsync(mapPoint) - Stack Overflow
KeithGemeinhart1
Here is a thread describing how to get Elevation from DTED. We got it working successfully using the info from the thread:
https://community.esri.com/message/674346-re-dted-as-a-local-elevation-source-net-wpf-v1000?commentI...
