Portal login on redirect without prompt
1127
04-05-2017 12:11 PM
ConnorWilliams
I am trying to write a programs that will login a user programatically into a ArcGIS portal.
Here is my scenario:
User logs in to application A, user clicks a link to the ArcGIS portal - I do not want them to have to login to the portal when they click that link because that have already logged into application A.
SO
I would like:
User logs in to application A, user clicks a button containing the portal link as an argument and redirects to application B. Application B logs the user into portal and redirects them with the link from application A - the user is redirected without being prompted to login.
The portal is using portal tier authentication and I am using javascript but I could also use .NET/C#
Any help on this would be great!
Thanks so much.
