Generate polygon ring from user input coordinates
6386
15
11-04-2016 06:36 AM
MuhammadFayaz
I want to develop a small application  that get coordinates from user as input and generate a list of it. then i want to show this as a polygon on the map.
I am unable to push the list to the polygon ring. Anybody can help please
I application is attached!
RobertScheitlin__GISP
Muhammad,
  Here is your code working
by Anonymous User
Not applicable
You can try this one..
but its need to be more specific
Default Editor
MuhammadFayaz
Dear Avinash,
I cannot reach to source of your sample, can you share!
by Anonymous User
Not applicable
MuhammadFayaz
Thank you Avinash, Robert did it for me...
Muhammad,
MuhammadFayaz
Robert,
Thank you very much for your time. This was exactly what i need.. Thanks again!
MuhammadFayaz
Dear Robert,
What if i want to use UTM projected coordinates to place graphics. I tried to change the spatialReference  to  { wkid: 32638 }. But it is not working..
It might be easy but i am new to custom development.. Any help!
Muhammed,
  It would look like this then:
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>Coordinate to Map</title>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css" />
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
    <script src="https://js.arcgis.com/4.1/"></script>
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
    <!--########## Map ###########-->
    <script>
        var app = {};
        require([
            "esri/Map",
            "esri/views/SceneView",
            "esri/widgets/Popup",
            "esri/geometry/Polygon",
            "esri/symbols/SimpleFillSymbol",
            "esri/tasks/GeometryService",
            "esri/tasks/support/ProjectParameters",
            "esri/config",
            "esri/Graphic", "dojo/dom", "dojo/on", "dojo/domReady!"
        ], function(
            Map, SceneView, Popup, Polygon,
            SimpleFillSymbol,
            GeometryService,
            ProjectParameters,
            esriConfig,
            Graphic, dom, on
            var map = new Map({
                basemap: "hybrid",
                ground: "world-elevation"
            var view = new SceneView({
                center: [43.940626, 26.346404],
                container: "viewDiv",
                map: map,
                zoom: 12,
                tilt: 30
            esriConfig.geometryServiceUrl = "https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer";
            view.on("click", function(event) {
                view.popup.location = event.mapPoint;
                // Displays the popup
                view.popup.visible = true;
            var polAtt = {
                Name: "Keystone Pipeline",
                Owner: "TransCanada",
                Length: "3,456 km"
             * Create a polygon graphic
            function showPolygon() {
                // Create a polygon geometry
                var polygon = new Polygon({
                    rings: [
                        [43.935018, 26.365905],
                        [43.958770, 26.366693],
                        [43.961578, 26.348339],
                        [43.933733, 26.342883]
                console.info(polygon.toJSON());
                // Create a symbol for rendering the graphic
                var fillSymbol = new SimpleFillSymbol({
                    color: [227, 139, 79, 0.8],
                    outline: { // autocasts as new SimpleLineSymbol()
                        color: [255, 255, 255],
                        width: 1
                 * Create a new graphic and add the geometry,
                var polygonGraphic = new Graphic({
                    geometry: polygon,
                    symbol: fillSymbol,
                    attributes: polAtt,
                    popupTemplate: { // autocasts as new PopupTemplate()
                        title: "{Name}",
                        content: [{
                            type: "fields",
                            fieldInfos: [{
                                fieldName: "Name"
                                fieldName: "Owner"
                                fieldName: "Length"
                view.graphics.addMany([polygonGraphic]);
                view.goTo([polygonGraphic]);
            app.addUserPolygon = function(json) {
                console.info(json);
                //return;
                view.graphics.removeAll();
                        width: 1
                // create the polygon and project it to the maps SR
                var poly =  new Polygon({
                  rings: json,
                  spatialReference: { wkid: 32638 }
                var params = new ProjectParameters({
                  geomerties: [poly],
                  outSR: map.spatialReference
                var geomSer = new GeometryService(esriConfig.geometryServiceUrl);
                geomSer.project(params).then(lang.hitch(this, function(geoms){
                      geometry: geoms[0],
                      symbol: fillSymbol,
                      attributes: polAtt,
                          title: "{Name}",
                          content: [{
                              type: "fields",
                              fieldInfos: [{
                                  fieldName: "Name"
                                  fieldName: "Owner"
                                  fieldName: "Length"
            // Add the graphics to the view's graphics layer
            on(dom.byId("showBtn"), "click", showPolygon);
    </script>
</head>
<body>
    <h1 id="heading">أحداثيات الى خريطة</h1>
    <h4> Please Enter Geographic Coordinates Clockwise! </h4>
    <input type="text" id="coord">
    <input type='button' onclick="changeText2(); clearCoord();" value='Submit' />
    <p>Coordinates List:</p>
    <ol id="demo"></ol>
    <button id="showBtn">Show Polygon on Map</button>
    <div id="viewDiv"></div>
    <script src="listCoord.js"></script>
</body>
</html>
MuhammadFayaz
Dear Robert,
I tried it but got the error  "Cannot read property 'wkid' of undefined".
