Custom layer (WMS) - example in AMD version
1564
09-08-2016 06:01 AM
WojciechRozkowski
I've found an example of creating custom request to WMS service written in non-AMD style:
Custom layer - WMS | ArcGIS API for JavaScript 3.17
I'm trying to implement this kind approach but in modern AMD approach.
Unfortunately, as a beginner, I don't know how to rewrite this example to fit AMD style. Especially the part with defining my.CityStatesRiversUSAWMSLayer() function with callback is out of my reach.
Could you please provide the mentioned example in AMD style?
RobertScheitlin__GISP
Wojciech,
   Here is the code updated to AMD:
<!DOCTYPE html>
<html>
  <head>
    <title>WMS</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
    <script src="https://js.arcgis.com/3.17/"></script>
    <script>
    var map;
    require([
      "dojo/_base/declare",
      "esri/map",
      "esri/geometry/Extent",
      "esri/layers/DynamicMapServiceLayer",
      "esri/SpatialReference",
      "dojo/domReady!"
    ], function(
      declare, Map, Extent,
      DynamicMapServiceLayer, SpatialReference
      declare("my.CityStatesRiversUSAWMSLayer", DynamicMapServiceLayer, {
        constructor: function() {
          this.initialExtent = this.fullExtent = new Extent({"xmin":-16476154.32,"ymin":2504688.54,"xmax":-6457400.14,"ymax":7514065.62,"spatialReference":{"wkid":102100}});
          this.spatialReference = new SpatialReference({wkid:102100});
          this.loaded = true;
          this.onLoad(this);
        getImageUrl: function(extent, width, height, callback) {
          var params = {
            request:"GetMap",
            transparent:true,
            format:"image/png",
            bgcolor:"ffffff",
            version:"1.1.1",
            layers:"0,1",
            styles: "default,default",
            exceptions: "application/vnd.ogc.se_xml",
            //changing values
            bbox:extent.xmin + "," + extent.ymin + "," + extent.xmax + "," + extent.ymax,
            srs: "EPSG:" + extent.spatialReference.wkid,
            width: width,
            height: height
          callback("https://sampleserver1.arcgisonline.com/arcgis/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServ...?" + dojo.objectToQuery(params));
      map = new Map("map", {
        basemap: "satellite",
        center: [-103.008, 40.98],
        zoom: 4
      map.addLayer(new my.CityStatesRiversUSAWMSLayer());
    </script>
  </head>
  <body class="claro">
    <div id="map"  style="position:relative; width:1024px; height:512px; border:2px solid #000;"></div>
  </body>
</html>
Wojciech,
<!DOCTYPE html>
<html>
  <head>
    <title>WMS</title>
    <script>
    var map;
    require([
      "esri/map",
      "dojo/domReady!"
    ], function(
          this.loaded = true;
          this.onLoad(this);
          var params = {
            request:"GetMap",
            transparent:true,
            format:"image/png",
            bgcolor:"ffffff",
            version:"1.1.1",
            layers:"0,1",
            //changing values
            width: width,
            height: height
        zoom: 4
    </script>
  </head>
  </body>
</html>
WojciechRozkowski
Thank you very much Robert.
Someone from Esri can take your work and update the example:)
