how to Get all selected features Ids from a buffer results
1706
08-11-2016 12:21 AM
HushamHassan
Is it Possible to get prop_id  for each  Parcels   selected in a buffer results,  so I can pass them to  SQL query,  for example  if the buffer return  10  parcels  I need to get all the prop_id for the 10 parcels..
_showBuffer: function(features){
            $('.results.multipleBuffer').hide();
            var bufferSymbol = symbols.buffer;
            map.graphics.clear();
            if (features.length > 0) {
                var graphic = new Graphic(features[0], bufferSymbol);
                map.graphics.add(graphic);
                queryTask = new QueryTask(config.mapServices.dynamic + "/" + config.parcelLayerID);
                var bufferQuery = new Query();
                bufferQuery.outFields = ["*"];
                bufferQuery.returnGeometry = true;
                bufferQuery.geometry = features[0];
                queryTask.execute(bufferQuery).then(lang.hitch( this, function (fset) {
                    var bufferFeatures = fset.features;
                    console.log(bufferFeatures);
                    this._createTable(bufferFeatures);
                    //console.log(bufferFeatures);
                    navEvent('point');
                    if (fset.features.length > 0) {
                        var allGraphics = array.map(fset.features, function (feature) {
                            return feature;
                        unionExtent = graphicsUtils.graphicsExtent(allGraphics);
                        map.setExtent(unionExtent.expand(1.5));
RobertScheitlin__GISP
Husham,
  You are already looping through the results so it would simply be something like this:
                        var Gids = [];
                            Gids.push(feature.attributes.prop_id);
                            return feature;
                    //Then you use the Gids array to populate your SQL query i.e. var sqlText = "Select * from TableX Where FieldX IN (" + Gids.join() + ")";
Husham,
  Sure you can. You already have the graphics that are selected based on intersecting the buffer(s). So you would loop through the fset.features and once you have a single feature (i.e. var feat = fset.features😉 then you would get that features attributes property and then the field you are interested in (i.e. fset.features[0].attributes.prop_id).
HushamHassan
Thank you Robert,  Could you please provide code sample for the loop.
Regards
Husham,
                        var Gids = [];
                            return feature;
HushamHassan
Robert,
That is really great Help.
Thank you
