toggle feature?
4129
5
07-13-2016 09:56 PM
AhmadSopian1
<script type="text/javascript">
    dojo.require("dijit.dijit"); // optimize: load dijit layer
    dojo.require("dijit.layout.BorderContainer");
    dojo.require("dijit.layout.ContentPane");
    dojo.require("esri.map");
    dojo.require("esri.toolbars.draw");
    dojo.require("esri.layers.FeatureLayer");
    dojo.require("esri.tasks.query");
    dojo.require("dojox.grid.DataGrid");
    dojo.require("dojo.data.ItemFileReadStore");
    dojo.require("dijit.layout.TabContainer");
    var map, toolbar;
    var featureLayer;
    function init() {
        var initExtent = new esri.geometry.Extent({ "xmin": 9773773.173194762, "ymin": -1718113.5089816158, "xmax": 16446419.994375736, "ymax": 1187716.5583068724, "spatialReference": { "wkid": 102100} });
        map = new esri.Map("map", {
            extent: initExtent
        dojo.connect(map, 'onLoad', function (map) {
            identifyTask = new esri.tasks.IdentifyTask("http://gisserver/ArcGIS/rest/services/multi/MapServer");
            identifyParams = new esri.tasks.IdentifyParameters();
            identifyParams.tolerance = 3;
            identifyParams.returnGeometry = true;
            identifyParams.layerIds = [0, 1, 2];
            identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
            identifyParams.width = map.width;
            identifyParams.height = map.height;
            //initialize the toolbar
            toolBar = new esri.toolbars.Draw(map);
            dojo.connect(toolBar, "onDrawEnd", onDrawEnd);
            //resize the map when the browser resizes
            dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
        var basemapUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl);
        var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("gisserver/ArcGIS/rest/services/multi/MapServer", { opacity: 100 });
        map.addLayer(basemap);
        map.addLayer(landBaseLayer);
    function onDrawEnd(extent) {
        toolBar.deactivate();
        executeIdentifyTask(extent);
    function executeIdentifyTask(geom) {
        //clear the graphics layer
        map.graphics.clear();
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
                                new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT,
                                new dojo.Color([151, 249, 0, .80]), 3),
                                new dojo.Color([151, 249, 0, 0.45]));
        identifyParams.geometry = geom;
        identifyParams.mapExtent = map.extent;
        identifyTask.execute(identifyParams, function (response) {
            var waItems = [];
            var weItems = [];
            var basItems = [];
            dojo.forEach(response, function (result) {
                var feature = result.feature;
                //add selected feature to graphics layer
                feature.setSymbol(polygonSymbol);
                map.graphics.add(feature);
                if (result.layerName === 'We') {
                    weItems.push(feature.attributes);
                } else if (result.layerName === 'wa') {
                    waItems.push(feature.attributes);
                } else if (result.layerName === 'Bas') {
                    basItems.push(feature.attributes);
            //update the data grid
            var waStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: waItems} });
            gridwa.setStore(waStore);
            var weStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: weItems} });
            gridwe.setStore(weStore);
            var basStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: basItems} });
            gridbas.setStore(basStore);
    //show map on load
    dojo.addOnLoad(init);
    </script>
Kelly Hutchins
help create toggle layer for select multiple features
AdrianWelsh
MVP Honored Contributor
Ahmad,
Can you give some more detail to what is happening (or is nothing happening)? Any errors?
Also, it may help people to read it better if you were to block your code.
To do this, click on the "Use advanced editor", then the double arrows --> Syntax highlighting --> JavaScript
AhmadSopian1
thanks for correction Adrian Welsh, Adrian Welsh
I do not know where I should put the source code toggle Layer adrian,
can u help me?
RobertScheitlin__GISP
Ahmad,
  1. Please provide your full html code.
  2. Please outline your desired workflow in detail. What do you mean by "help create toggle layer for select multiple features"?
AhmadSopian1
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/soria/soria.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dojox/grid/resources/SoriaGrid.css">
    <style type="text/css">
      html, body {
        height: 100%; width: 100%; margin: 0;
      body{
        background-color:white; overflow:hidden;
        font-family: "Trebuchet MS";
      .roundedCorners{
        -moz-border-radius: 4px;
      #header {
        border: solid 2px #7EABCD;
        background-color:white; color:peru; font-size:18pt;
        text-align:center; font-weight:bold; height:60px;
      #subheader {
        font-size:small;
        color: peru;
      #rightPane{
        color:peru;
        border: solid 2px cornflowerblue;
        width:30%;
        overflow:hidden;
      #map {
        border:solid 2px cornflowerblue;
      #footer {
        background-color:white;color:peru;font-size:10pt; text-align:center; height:40px;
      .soria .dojoxGridHeader .dojoxGridCell   {
        color:peru !important;
    </style>
        var djConfig = {
            parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6">
    </script>
        var map, toolbar;
        var featureLayer;
        function init() {
                extent: initExtent
                identifyTask = new esri.tasks.IdentifyTask("http://servergis/ArcGIS/rest/services/multi/MapServer");
            var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://servergis/ArcGIS/rest/services/multi/MapServer", { opacity: 100 });
                var waItems = [];
                var weItems = [];
                var basItems = [];
                    } else if (result.layerName === 'Wa') {
        //show map on load
    </script>
  </head>
  <body class="soria">
    <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline"
    gutters="false" style="width:100%; height:100%;">
      <div id="map" dojotype="dijit.layout.ContentPane" class="roundedCorners" region="center"></div>
      <div dojotype="dijit.layout.ContentPane" id="rightPane" class="roundedCorners" region="right"  splitter="true" >
        <button dojoType="dijit.form.Button"  onClick="toolBar.activate(esri.toolbars.Draw.EXTENT);">Select</button>
        <div dojotype='dijit.layout.TabContainer'>
            <div dojotype='dijit.layout.ContentPane' title = 'Result' selected='true'>
            Wa
                <table dojotype="dojox.grid.DataGrid" jsid="gridwa" id="gridwa" style="width:100%;height:50%;" selectionMode="none" title="Wa">
                 <thead title="Wa">
                    <tr style="cursor:pointer;" onclick="zoomToLayer">
                      <th field="Wa">Wa</th>
                      <th field="OPERATOR" width="100%">OPERATOR</th>
                    </tr>
                  </thead>
                </table>
                <br />
                We
                <table dojotype="dojox.grid.DataGrid" jsid="gridwe" id="gridwe" style="width:100%;height:50%;" selectionMode="none" title="We">
                 <thead title="We">
                    <tr >
                      <th field="WE ">WE</th>
                      <th field='OPERATOR' width="100%">OPERATOR</th>
                    </tr>
                  </thead>
                </table>
                <br />
                Bas
                <table dojotype="dojox.grid.DataGrid" jsid="gridbas" id="gridbas" style="width:100%;height:50%;" selectionMode="none" title="bas">
                 <thead title="bas">
                    <tr>
                      <th field="BAS" width="100%">BAS</th>
                    </tr>
                  </thead>
                </table>
                </div>
        </div>
      </div>
      </div>
  </body>
</html>
and i mean create
visible layers in my code for example
Thanks Robert Scheitlin...
Ahmad,
  I can't even find documentation on JS API 2.6. Why have you not updated your code to use the latest API? I am not sure I can help with such old code.
Not sure if this would work because I can not find the 2.6 docs but here is how I think it should work:
    <title></title>
</head>
<body>
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>
    </title>
        html,
        body {
            height: 100%;
            width: 100%;
            margin: 0;
        body {
            background-color: white;
            overflow: hidden;
        .roundedCorners {
        #header {
            color: peru;
            font-size: 18pt;
            text-align: center;
            font-weight: bold;
            height: 60px;
        #subheader {
            font-size: small;
            color: peru;
        #rightPane {
            color: peru;
            width: 30%;
            overflow: hidden;
        #map {
        #footer {
            color: peru;
            font-size: 10pt;
            text-align: center;
            height: 40px;
            color: peru !important;
    </style>
        var djConfig = {
            parseOnLoad: true
    </script>
    </script>
        var map, toolbar;
        var featureLayer, landBaseLayer;
        function init() {
                    "wkid": 102100
                extent: initExtent
            dojo.connect(dojo.byId("layer0CheckBox"), "change", updateLayerVisibility);
            dojo.connect(dojo.byId("layer1CheckBox"), "change", updateLayerVisibility);
            dojo.connect(dojo.byId("layer2CheckBox"), "change", updateLayerVisibility);
            dojo.connect(map, 'onLoad', function(map) {
                 opacity: 100
        function updateLayerVisibility () {
            var inputs = dojo.query(".list_item");
            var inputCount = inputs.length;
            visibleLayerIds = [];
            for (var i = 0; i < inputCount; i++) {
              if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
            if (visibleLayerIds.length === 0) {
              visibleLayerIds.push(-1);
            landBaseLayer.setVisibleLayers(visibleLayerIds);
            identifyTask.execute(identifyParams, function(response) {
                var waItems = [];
                var weItems = [];
                var basItems = [];
                dojo.forEach(response, function(result) {
                    data: {
                        identifier: 'FID',
                        items: waItems
                    data: {
                        identifier: 'FID',
                        items: weItems
                    data: {
                        identifier: 'FID',
                        items: basItems
        //show map on load
    </script>
    </head>
        <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%; height:100%;">
            <div dojotype="dijit.layout.ContentPane" id="rightPane" class="roundedCorners" region="right" splitter="true">
                <div dojotype="dijit.layout.ContentPane" region="top" splitter="false" style="width:100%; height:5%;">
                  Layer List : <span id="layer_list">
                    <input type='checkbox' class='list_item' id='layer0CheckBox' value=0 />Wa
                    <input type='checkbox' class='list_item' id='layer1CheckBox' value=1 />We
                    <input type='checkbox' class='list_item' id='layer2CheckBox' value=2 />Bas
                  </span>
                </div>
                <div dojotype="dijit.layout.ContentPane" region="bottom" splitter="false" style="width:100%; height:95%;">
                      <div dojotype='dijit.layout.ContentPane' title='Result' selected='true'>
                          Wa
                          <table dojotype="dojox.grid.DataGrid" jsid="gridwa" id="gridwa" style="width:100%;height:29%;" selectionMode="none" title="Wa">
                              <thead title="Wa">
                                  </tr>
                              </thead>
                          </table>
                          <br /> We
                          <table dojotype="dojox.grid.DataGrid" jsid="gridwe" id="gridwe" style="width:100%;height:29%;" selectionMode="none" title="We">
                              <thead title="We">
                                  <tr>
                                  </tr>
                              </thead>
                          </table>
                          <br /> Bas
                          <table dojotype="dojox.grid.DataGrid" jsid="gridbas" id="gridbas" style="width:100%;height:29%;" selectionMode="none" title="bas">
                              <thead title="bas">
                                  <tr>
                                  </tr>
                              </thead>
                          </table>
                      </div>
                  </div>
                </div>
            </div>
        </div>
    </body>
    </html>
