SDE callback error on st_intersects AND st_buffer
5896
7
07-01-2016 03:22 AM
NicolaBraccini
Hi everybody.
I am having a problem with the following query run on Oracle 11g with SDE 10.1:
SELECT mg.codice
  FROM mg_table mg,
     SELECT ct.shape
     FROM ct_table ct
     WHERE ct.strno = 'xxx' AND ct.anno = 2015
  ) c
  WHERE SDE.st_intersects(mg.shape, SDE.st_buffer(c.shape, 30)) = 0
produces the following generic exception:
ORA-28579: network error during callback from external procedure agent:
ORA-06512: at 'SDE.ST_GEOMETRY_SHAPELIB_PKG', line 325
ORA-06512: at 'SDE.ST_GEOMETRY_OPERATORS', line 1331
I tried to reproduce the error on a different server with an identical database but with SDE 10.2 installed and the exception never occurs.
Does SDE 10.1 version include a different implementation of st_buffer or st_intersects respect to 10.2 or 10.3 version? Upgrading the first server to 10.3 could solve this kind of problems?
Tommaso
JayantaPoddar
By 11.1, are you referring to Oracle release 11.1?
Esri recommends to work on 11.2.0.4 (11g R2) for Oracle 11g users. See the link below for details:
http://desktop.arcgis.com/en/arcmap/10.3/get-started/system-requirements/database-requirements-oracl...
Oracle 11.2.0.3 is the base supported version for 11g. However there are several issues customers are encountering in 11.2.0.3. Therefore, Esri recommends moving to 11.2.0.4.
Think Location
PanagiotisPapadopoulos
I propose to check if the Oracle extproc is set up correctly for direct ST_GEOMETRY SQL queries.
Also check for invalid objects on Oracle.
An another idea is to place 10.2 ST_LIBRARY dll on 10.1 SDE database in order to avoid any problems with 10.1 version of ST library dll version. Searching on ESRI support you can find some problem with that version
NIM104545: When using ST_Intersects with ST_Buffer on large fea..
NicolaBraccini
Hi Panagiotis,
the Oracle extproc seems to be set up correctly. I was able to run other successfully other queries.
Nice
it is better to try to change the ST Library dll version
ChristianWells
Panagiotis Papadopoulos​ and Nicola Braccini​, each version of the Enterprise Geodatabase (SDE) is explicitly tied to its st_geometry.dll (Windows) or libst_shapelib.so (Linux/UNIX) file. To upgrade, both the geodatabase and file need to be upgraded. Although, it may "work" by changing the dll, this is not recommended or certified.
There are a number of bugs similar to this in versions 10.1, 10.2.x, and 10.3.x which were fixed at 10.4.x.
NicolaBraccini
Thank you Christian.
Currently I cannot upgrade the geodatabe or change the dll on that server. I contacted ESRI support to know if there is a way to bypass this bug using the 10.1 version.
NicolaBraccini
Hi Jayanta,
I made a mistake writing the post. Actually, I was referring to SDE 10.1 and SDE 10.2. I updated the post.
Anyway, I used Oracle 11.2.0.1.0, so maybe the problem is in the st_geometry library.
