Editor widget sometimes hides selected graphic
4508
8
06-27-2016 08:49 AM
Haider_Ali
I am having problem editing line layer with editor widget
1) If i double click the graphic the selected features disappears sometimes
2) If i select the graphics and then select new selection from toolbar and select the already select feature  it disappears
I cant understand why its happening , below is jsfiddle code of the Editor widget with a single polyline please draw and test.
Edit fiddle - JSFiddle
Tags (1)
thejuskambi
Looks like a issue with IE only. I am not seeing the behavior in FF.
Haider_Ali
I am using chrome, i also tested it on firefox (same issue), thejus kambi Did you tested both scenarios?
thejuskambi
I have tested it again, and confirm the behaviour as described by you in both the browsers.
Haider_Ali
Is it an editor widget bug , if yes then how can i report it? Its urgent.
RobertScheitlin__GISP
You will have to call esri tech support and report the bug. If you are not a US customer then you can report it to your local esri rep.
Haider_Ali
Can you please confirm that it is a bug?
Haider,
  Esri is the one that has to confirm it is a bug.
Haider_Ali
Please check the fiddle above to see if i am not missing any configuration.
