Query a FeatureLayerView With Geometry in Version 10.22
1718
07-12-2016 09:04 AM
chuckfrank
Is it possible to query a FeatureLayerView of a hosted feature service from AGS 10.22?  The code below is not working:
    view.whenLayerView(featureLayerProjects).then(function (lyrView) {
        lyrView.watch("updating", function (val) {
            if (!val) {  // wait for the layer view to finish updating
                view.on("click", function (evt) {
                    var circle = new Circle({
                        center: evt.mapPoint,
                        radius: 1000
                    console.log(circle);
                    var query = new Query();
                    query.geometry = circle;
                    query.spatialRelationship = "intersects";
                    lyrView.queryFeatures(query).then(function (results) {
                        console.log(results);  // prints the array of client-side graphics to the console
            else {
                console.log('something else happened');
The code above comes is modified from an example I found in the documentation here: FeatureLayerView | API Reference | ArcGIS API for JavaScript 4.0
When I don't pass a query to the queryFeatures() function all of the features in the featureSet are returned.  When I do pass a query, I get an error in the console:  Object {name: "QueryEngine", message: "Invalid query", details: undefined} "
The larger problem I'm trying to solve is to click a point and get the attributes.  I though it would be possible to use the FeatureLayerView client side and not send a query to the server, but I cannot find a way to do it.  Is it because the server version is not new enough?
Chuck
