Create off-panel widget to display information automatically after splash screen
11997
22
06-17-2016 10:45 AM
WilliamMiller4
I would like to show additional information after the user agrees to the terms & conditions on the splash screen. What ESRI or DOJO class (a dijit/Dialog perhaps?) should I use to display this information as an off-panel widget and how would I have it display automatically upon the close of the splash screen? Any help is much appreciated.
SteveCole
Honored Contributor
I'm not using WebApp Builder but here's how I've accomplished something that I think looks similar. I have a separate JS file that constructs the dialog (see attached code) and the dialog is created/displayed on a button click that triggers the showHelp() function inside the JS file. I've also attached a screenshot of the dialog.
The code isn't pasting very well into the post (Thanks, GeoNet!) so I'm attaching it as a file.
RobertScheitlin__GISP
William,
  I would use jimu/dijits/Message.js for that.
WilliamMiller4
Hi Robert,
Would I include this in the define section of my widget? Is there any more documentation on this other than what is in the Message.js file itself? Also, can an off-panel widget be added to the headerController, and if not, where?
William
William,
  Based on your scenario I would just add this to the splash widgets Widget.js in the define and not worry at all with adding a new widget. No there is no documentation on the Message dijit other then what you can derive from the code in the Message.js
WilliamMiller4
Robert,
I added 'jimu/dijit/Message' to the splash widget's define and Message to the argument list. Where/How do I override the empty message string in Message.js?
William
William,
  To use the Message dijit is is as simple as:
new Message({
    titleLabel: "Some Title,
    message: "Some message"
or as advanced as:
          var qMessage = new Message({
              type: 'question',
              titleLabel: this.nls.warning,
              message: this.nls.graphicgeomtypemsg1 + "\n\n" + this.nls.graphicgeomtypemsg2,
              buttons: [{
                label: this.nls._continue,
                onClick: lang.hitch(this, lang.hitch(this, function () {
                  qMessage.close();
                  this.lastDrawCommonType = commontype;
                  this.lastDrawTool = geotype;
                  this.drawBox.clear();
                  this.garr = [];
                label: this.nls.cancel,
                  qMessage.close();
                  this.drawBox.activate(this.lastDrawTool);
WilliamMiller4
Robert,
Would I add one of these to the onOkClick function in the splash widget?
yep
WilliamMiller4
Hi Robert,
Thank you for your suggestion, but I should have been more specific in my original question. The reason I was thinking of making a widget was because I wanted users to be able to reference the information presented after the splash screen at any point in the application. I don't want the widget to be in a panel, as I would like it to be centered on the screen. I also wanted to include tabs to help organize the data. I'm hoping to include this widget in the headerController. Any thoughts on what ESRI/DOJO class I should use for this widget? Thanks again for your attention to this matter.
William
WIlliam,
  There is no pre-made dijit that meets your needs then. When working with out of panel widgets almost all of the UI development is on you as the developer.
