Run Web AppBuilder for Developers under HTTP
3669
06-17-2016 02:13 AM
ZdeněkSoldán
I installed Web AppBuilder for Developers on our geoportal. When I run starup.bat Web AppBuilder always start under https even if I rewrite url adress to http it switch to https again. I have a web map where services are loaded under HTTP and when I want to add this web map to web appbuilder in developer tools I see erros with mixed content:   Mixed Content: The page was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint  This request has been blocked; the content must be served over HTTPS.
Is there any possibility how to run web AppBuilder under http? Or any other solutions to this problem?
Thanks for any help.
Tags (1)
RobertScheitlin__GISP
Zdendek,  When you mention Geoportal do you mean you have Portal on premise? If so then Portal is only run using HTTPS and your rule that you are registering is using https so the WAB dev will always be in https. If you did not mean you have on premise Portal, then make sure you delete the signininfo.json and make sure to use an http address when specifying your portal rule and go back to the registering the app sets and make sure you do not use any https address for your re-directs.
ZdeněkSoldán
Hello Robert,
Yes I meat Portal. So is any possibility how to use web maps with http connections in WAB registred on Portal?
Not that I am aware of.
ZdeněkSoldán
Ok,
Thank you for your answers
