Geoprocessing with JS API 4.0
4659
6
06-13-2016 09:08 AM
AbbyGallegos
I am having trouble figuring out how to call an asynchronous geoprocessing service with the new 4.0 API.  I have looked at the example for calling the sychronous service, but I didn't see any examples for an asynchronous service.  I understand that it requires using a "promise", which I am trying to learn to use, and it appears that I have to use "getResultImageLayer()" or "getResultImage()", but I don't understand what I would use for the parameters "resultName" and "imageParams".  In the 3.x API, I had to use the URL for the MapServer of the asynchronous service along with the JobId, which would return the result as a layer.   I guess I am just confused how this now works in the 4.0 API.  I wish there was an example of using an asychronous service.   Does anyone know of any examples?
Abby
UndralBatsukh
Hi there,
Please try this. I tested it and it works:
function drawResultData(result) {
          console.log(result);
          var resultLayer = gp.getResultImageLayer(result.jobId);
          map.layers.add(resultLayer);
UndralBatsukh
Hi there,
As you have mentioned submiJob() returns an instance of promise and it takes 3 arguments:
'callback'- the function called when the promise is resolved
'errback', - the function called when the promise is rejected.
'progback' - the function called when the promise has progress.
More about Promise check this document​.
So you can run a geoprocessing service asynchronously as shown below:
//gp params as required
var params = {
     "in_features": featureSet,
     "material_type": "Chlorine"
//run gp service
gp.submitJob(params).then(gpResultData, errBack, progTest);
// This function is called when gp resolves successfully
// result contains GP service result
function gpResultData(result) {
// This function is called if gp service is rejected
function errBack(err){
    console.log("gp error: ", err);
//use this function to check on the progress of gp service
function progTest(value){
   console.log(value.jobStatus);
   console.log(value);
Hope this helps.
AbbyGallegos
Thanks Undral for the reply, but I am still a bit confused on how to call "getResultImageLayer" to display the result on the map.  Also, I am getting an error that I don't understand when trying to create a new "ImageParameters()".  See attached code.
Thanks for your help.
Abby
UndralBatsukh
I deleted last message because I failed to understand your issue. I have not tried it myself but pass in null for the ImageParameters when calling getResultImageLayer. I will test it here shortly.
AbbyGallegos
Undral, you stated that I should be able to access the results of my GP service from the result object.  The output of the service that I am trying to access has a Data Type = GPRasterDataLayer.  When I was using the 3.x API, I was able to just instantiate a new ArcGISDynamicMapServiceLayer with the MapService URL and the jobId appended to it, then add the layer to the map.  It worked in 3.16 API.
However, I am now using the 4.0 API with 3D, and I do see the result object in the console.log(result), but I am confused as to how to add it to the map for display.  The job succeeds and within the result object I see a "results" with "Viewer_Viewshed" (the data layer I am trying to display).  However, I don't know how to add it to the map to display it in my 3D view.  This is the code I am using:
function drawResult(result) {
     var gpMapServiceURL = gpMapUrl + "/" + result.jobId;       // get the url to the MapService with the JobId
     var resultImage = new MapImageLayer({
          url: gpMapServiceURL
     map.add(resultImage);             // Not able to see the result on the map
I get no errors (using Firebug in firefox), but the result image does not show up on the map.  By the way, it does work using 3.16 API.
I really appreciate your help.  I would like to get this to work.
Abby
UndralBatsukh
Hi there,
AbbyGallegos
Awsome, thanks Undral, this works for what I needed.
I really appreciate your help!
Abby
