How can I check if any feature service which is not displayed in My Content (AGOL) is consuming credits or not?
3432
5
06-07-2016 09:01 AM
DebojyotiMallick2
There may be deleted feature services on the My Content page which may still be consuming credits.
How do I find out the feature services and then prevent the unnecessary credit consumption?
Service Definition files are also missing for the same feature services that have been deleted.
KellyGerrow
Esri Alum
If you think that your credit charges for feature storage are higher than you would expect, I would recommend contacting technical support to look into the issue further.
Here is a link to a sample script on github that reports all of the item sizes of your hosted feature services to a csv file using python. This may help in understanding the size of the services that are in your organization.
Cheers,
Kelly
KellyGerrow
Esri Alum
Cheers,
Kelly
DebojyotiMallick
Hi Kelly,
             I did follow the workaround you suggested but the python script did not execute at my end. The edits i performed on the script is given below.
Regards,
Debojyoti.
KellyGerrow
Esri Alum
What is the error message that you are receiving?
-Kelly
DebojyotiMallick
Hi Kelly,
             The script just seems to run . I have just 12 feature layers in My Content and the loop seems to be an infinite one with no results in the end.
Regards,
Debojyoti
KellyGerrow
Esri Alum
As some follow up, it looks like the error is in how the file location is being entered.
If you are going to hard code the location to the script, remove raw_input. The proper line should read:
fileLoc = r"c:/inputfolder/input.csv"
-Kelly
