Can a Python script be triggered to run based on a ArcGIS Server Log message?
3061
06-06-2016 12:18 PM
SethStark1
I'm using ArcGIS Server 10.2. I am getting a reoccurring message in my server logs related to one specific service. When this message occurs, the service stops working until I stop and restart the service. Then it works again for a few hours, before the whole process repeats itself.
Here is the message:
Level: SEVERE
Message: "A database error occurred"
Source: TSI_MH_Edit.MapServer
Code: 17000
I cannot fix the root cause of this problem (I am working under time constraints--eventually I will fix it), so I'm wondering if, in the meantime, a script could be triggered to run which would stop and start the service in question when this error occurs. So, when the message above appears in the Server Logs, it would trigger a script to stop and restart the service.
Has anyone ever done anything like this?
JonathanQuinn
Esri Notable Contributor
Sure can!  You can use Python to parse the logs by querying them, and then if it finds a certain code, (or just query the logs for a message code, for example code 17000), it can then stop and start the service, send you an email, whatever you'd like.  The two links to documentation contain code samples that can be easily modified.  This can run as a scheduled task within Windows Task Scheduler, see this help document or this blog post.
AnjulPandey
@JonathanQuinn
I would appreciate it if you could suggest the following -
  • Is there a way to obtain usage statistics of vector tile service published on ArcGIS Server?
  • Has anyone created a script or notebook to collect a list of all the vector tile packages with their storage size and usage statistics?
  • Logs for map and vector tiles generated by publishing services on ArcGIS Server?
