Installing older versions of Numpy + Matplotlib (virturalenvwrapper-win)
11988
06-02-2016 01:36 AM
PeterWilson
I'm busy setting up a virtualenv for my ArcGIS 10.3.1 Python (2.7.8 64bit) Development. I've created a new virtualenv using virtualenvwrapper-win and it's installed a clean installation of Python based on the current default version installed by ArcGIS. I trying to install the ArcGIS required versions of the following packages:
  • Numpy (1.7.1)
  • matplotlib (1.3.0)
  • xlrd (0.9.2)
  • xwlt (0.7.5)
  • Pyparsing (1.5.7)
When I try to install Numpy (1.7.1) and matplotlib (1.3.0) via command line using pip install, it fails as it can't find a Python Wheel for the following and only finds a zipped file that it tries to compile and fails. I don't have any experience in how to achieve the following. I tried downloading an executional installation for the following but unfortunately it doesn't give you the option to select an alternative installation directory but the default Python installation under my C Drive. Any help to solve the following will truly be appreciated.
ArcGIS 10.3.1 Python Requirements
Virtualenvwrapper-win: pip install Numpy (1.7.1)
Virtualenvwrapper-win: pip install Numpy (1.7.1) error message unable to compile
Numpy 1.7.1 Executional Installation (Unable to change Python Directory or Installation Directory)
Luke_Pinner
MVP Regular Contributor
The installer exe is executable zip file. Just extract it using 7zip or similar and copy the numpy folder and numpy-1.7.1-py2.7.egg-info (they're under the PLATLIB folder in the extracted exe) to your virtualenvs site packages folder.
Or you could copy them from your existing python installation, or even use virtualenv --system-site-packages so your virtualenv can access the already installed numpy and matplotlib.
Luke_Pinner
PeterWilson
Hi Luke
Thanks for the following, truly appreciated.
PeterWilson
Hi Luke
Thanks for your help, I was able to install the correct Python packages based on your advice.
