Problem with changing Spatial Reference of data frame using Python
4494
10-11-2012 12:18 PM
CrystalCarreon
Hi-
I am trying to understand how to change the coordinate system of a data frame using python. I have tried the following code but itdoesn't seem to work:
import arcpy.mapping
MXD = arcpy.mapping.MapDocument(Path to .mxd)
prjFile = Path to .prj file <-- NOTE: I am not using the InstalDir/Coordinate Systems files.
sr = arcpy.spatialReference(prjFile)
for DF in arcpy.mapping.ListDataFrames(MXD):
   DF.spatialReference = sr
It seems I can get properties such as the name, type etc. of the data frame coordinate system just fine but I am unable to set thecoordinate system using the above code. I do note that I am NOT using the install coordinate system files. Reason being is I am working on a citrix version of ArcMap, so effectively I don't have access to these files as a normal desktop user would. I was thinking Icould just copy the reference system from a feature class sitting on a computer I do have access to but, again, this doesn't seem to work. Do I need to have access to the installation coordinate systems files in order for this to work? Or is there a way around this? Or is my code totally wrong?
Any help is much appreciated!
Crystal
JakeSkinner
Esri Esteemed Contributor
Hi Crystal,
Are you saving your MXD after you apply the change?  Ex:
import arcpy
from arcpy import mapping
prjFile = r"C:\DATA\VECTOR\LOCAL\chester_county.prj"
sr = arcpy.SpatialReference(prjFile)
mxd = mapping.MapDocument(r"C:\temp\python\Airports.mxd")
for df in arcpy.mapping.ListDataFrames(mxd):
   df.spatialReference = sr
mxd.save()
del mxd
CrystalCarreon
I feel embarrassed to say this but no, I hadn't saved and that worked. It is working now. THANK YOU!
DylanKennard
You can also pipe in a WKID code in replace of a prjFile like sr = arcpy.SpatialReference(3857) which is the Web Mercator Projection to bypass that project file step.  Also I got hung up on the df.spatialReference = sr .....I capitalized Spatial as some help articles on ESRI reference it that way.  Thanks for the clear exacting code! It helped me stop pulling my hair out.
