Dear all i am using google as a base ma.i find all of examples but all are in legacy modules.I am using amd dojo.how to add these it should work for me.
<script type="text/javascript">
var djConfig = {
parseOnLoad: true,
baseUrl: './',
modulePaths: {
// if use local copy, make sure the path reference is relative to 'baseUrl', e.g.:
//'agsjs': '../build/agsjs'
// use absolute path for online version. Note sometimes googlecode.com can be slow.
'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.07/build/agsjs'
</script>
require([
"esri/dijit/BasemapGallery", "dojo/_base/json", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!"
], function ( BasemapGallery, dojoJson,CP,TP ) {
function createBasemapGallery() {
//Manually create a list of basemaps to display
basemaps.push(new esri.dijit.Basemap({
layers: [new esri.dijit.BasemapLayer({
type: 'GoogleMapsRoad'
title: "Google Road",
thumbnailUrl: "images/icons/GoogleRoads.jpg"
type: 'GoogleMapsSatellite'
title: "Google Satellite",
thumbnailUrl: "images/icons/GoogleSatelite.jpg"
type: 'GoogleMapsHybrid'
title: "Google Hybrid",
thumbnailUrl: "images/icons/GoogleHybrid.jpg"
var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, basemaps: basemaps, bingMapsKey: "Au4pcSZ", google: {
apiOptions:{ // google api options.
v: 3.6,
}, map: map }, "basemapGallery");
some code is not there.please help.Beacuse on my click event all other base map change even bing map com on click basemap gallery.only google map not come.please help.
