Can I make a button a toggle for multiple feature layers?
2287
03-24-2016 08:53 AM
NMWater
Hi all! Thanks for taking the time to look into this.
I have two buttons that I added manually into my webmap. One of them is a hover dropdown that shows my layers.
I have six feature layers in total, however 3 of the layers are in inches and 3 are in millimeters. The other button is my unit button (buttona).When I click my unit button (buttona)  the inner.HTML flip flops between Inches and Millimeters (see code below), is there a way to program buttona so that this button looks for the current layer that is currently showing and after its clicked it would display its counter part?
For example: If I have a county layer displaying in inches, when I click "buttona", it would hide the inches layer and display the county millimeters layer? Any help would be greatly appreciated!
Kindest Regards,
Francisco Ochoa
var flipflop = false;
var buttona = document.getElementById("buttona");
buttona.onclick = function change() {
       if (!flipflop) {
            buttona.innerHTML = "Inches";
       } else {
            buttona.innerHTML = "Millimeters" }
  flipflop = !flipflop;
  function showcounties() {
  if ( buttona.innerHTML == "Millimeters" ) {
  showcountymm();
  else {
  showcountyin();
  function showHUC8() {
  {showhuc8mm();}
  else { showHUC8in();}};
  function showWPR() {
  {showwprmm();}
  else {showwprin();}};
  function showcountymm()  {
  featureLayer.show(); HUC8.hide(); WPR.hide(); CNTYin.hide(); HUC8in.hide(); WPRin.hide();}
  function showhuc8mm() {
  featureLayer.hide(); HUC8.show(); WPR.hide(); CNTYin.hide(); HUC8in.hide(); WPRin.hide();}
  function showwprmm() {
  featureLayer.hide(); HUC8.hide(); WPR.show(); CNTYin.hide(); HUC8in.hide(); WPRin.hide();}
  function showcountyin(){
  featureLayer.hide(); HUC8.hide(); WPR.hide(); CNTYin.show(); HUC8in.hide(); WPRin.hide();}
  function showHUC8in(){
  featureLayer.hide(); HUC8.hide(); WPR.hide(); CNTYin.hide(); HUC8in.show(); WPRin.hide();}
  function showwprin(){
  featureLayer.hide(); HUC8.hide(); WPR.hide(); CNTYin.hide(); HUC8in.hide(); WPRin.show();}
RobertScheitlin__GISP
NM Water,
  I think you are looking for something like this:
  if (WPR.visible || featurelayer.visible || HUC8.visible) {
    if(WPR.visible){
      showwprin();
    if(featurelayer.visible){
      showcountyin();
    if(HUC8.visible){
      showHUC8in();
  } else {
    buttona.innerHTML = "Millimeters";
    if(WPRin.visible){
      showwprmm();
      showcountymm();
    if(HUC8.visible){
      showHUC8mm();
NM Water,
    if(WPR.visible){
      showwprin();
      showcountyin();
    if(HUC8.visible){
      showHUC8in();
  } else {
    if(WPRin.visible){
      showwprmm();
      showcountymm();
    if(HUC8.visible){
      showHUC8mm();
NMWater
Thank you so much Robert! The code worked perfectly!
