Creating points from a spreadsheet w/o xy
4311
11
03-15-2016 10:52 AM
KrisGilbert1
How can I create points from a spreadsheet that do not contain xy? I just have a list of data, but some of that data includes location such as Section 1, Block 122.  I have a separate polygon layer that has all of the sections/blocks labeled, but I would like to add this information "automagically" without manually creating each point and then linking the data.  Thank you.
Tags (1)
DarrenWiens2
You are describing Joining data: Joins and relates—ArcGIS Pro | ArcGIS for Desktop
You will need to make a common, single column on which to make your join (e.g. "Section_Block" -> "1_122").
KrisGilbert1
But, I don't want the data to live in my polygon layer. I want it to create points within that polygon.  I could not find a way using join/relate that gave me what I was after.  Am I doing it wrong?
DarrenWiens2
Make points geometries, perhaps centroids, from the polygons and then join your tabular data to those.
KrisGilbert1
That doesn't sound like it will save me any work.  Some polygons will end up with 1 point and some will end up with 10. So, if I created centroids, I would need to create the max for each polygon and remove the extras, right?  Is there something I'm not thinking of?
DarrenWiens2
Okay, if you're talking about a one-to-many relationship, then you should look into Relates. Joins and relates—ArcGIS Pro | ArcGIS for Desktop
KrisGilbert1
I'll give it a try. Thank you for your time.
AdrianWelsh
MVP Honored Contributor
Hi K,
I like Darrens ideas. Maybe do this:
  1. Join your tabular data to the polygon (after making a concatenated field like Darren pointed out).
  2. In the join, be sure you click on 'all' the data instead of just matching data.
  3. Export this newly joined polygon layer to a new feature class.
  4. Then make centroids (like Darren suggested) of this new polygon feature class.
I believe that way it will keep all of your tabular data and then have it be the attributes of the new points (though, I would imagine the points would be on top of each other).
EDIT: I just saw Darren's post. Related tables might be the way to go.
KrisGilbert1
I'll give it a try. Thanks!
KellyGerrow
Esri Alum
Try using custom location types in ArcGIS Maps for Office:
Location types—Esri Maps for Office | ArcGIS
You can create a feature service with your data and use it to locate your data.
-Kelly
