Story Map Zoom Level
6180
03-08-2016 09:45 AM
TotranMai
I’ve downloaded a shortlist ESRI story map codes and try to set the fixed min/man map zoom level,
Some posts here advise to add minZoom and maxZoom properties to the core.js, however the shortlist story map code only came with MAIN.JS
\shortlist-storytelling-template-js-1.4.7\app\js\main.js
I tried to add the minzoom and maxzoom properties in the main.js but it didn’t work
var mapDeferred = esri.arcgis.utils.createMap(WEBMAP_ID, "map", {
mapOptions: {
slider: false,
wrapAround180:false
minZoom: 10,
maxZoom: 12
ignorePopups: true
Did I do something wrong? Please help!!!
WilsonLee
hi mark,
i found a solution, setting the var lod works for me.
                      "level": 13,
                      "resolution": 19.1092570712683,
                      "scale": 72223.819286
                      "level": 14,
                      "resolution": 9.55462853563415,
                      "scale": 36111.909643
                      "level": 15,
                      "resolution": 4.77731426794937,
                      "scale": 18055.954822
                     "level": 16,
                      "resolution": 2.38865713397468,
                      "scale": 9027.977411
  mapOptions: {
  slider: false,
  wrapAround180:false,
  lods: lods
  ignorePopups: true
MarkCooney
Hi Totran,
That should do the trick.  Have you tried clearing your browser cache and reloading?
Mark
WilsonLee
Hi Mark,
I cleared the browser cache and reloaded the site, but it's still not working (i can zoom in/out at all levels)
is it the api version issue?
thanks,
Wilson (I work with Totran)
WilsonLee
hi mark,
                      "level": 13,
                      "level": 14,
                      "level": 15,
                     "level": 16,
  mapOptions: {
  slider: false,
  lods: lods
  ignorePopups: true
